How Do You Calculate the Distance a Motorboat Travels After Engine Shutdown?
  • Thread starter Thread starter physicsss
The discussion revolves around calculating the distance a motorboat travels after its engine shuts off, given its initial speed and the effect of drag force proportional to its velocity. The problem involves concepts from kinematics and differential equations.
  • Participants explore the integration of a differential equation representing the motion of the motorboat. Questions arise regarding the integration process and the determination of constants involved, particularly the variable 'k'.
Several participants have offered insights into the integration of the motion equation and the use of initial conditions to solve for constants. There is an ongoing exploration of how to apply these conditions to find the necessary parameters for the solution.
Participants note the initial conditions provided in the problem, including the motorboat's speed at shutdown and its speed after a specified time. There is also mention of a reference book answer that some participants are trying to reconcile with their calculations.
physicsss
Help!
A motorboat traveling at a speed of 2.4 m/s shuts off its engines at t = 0. How far does it travel before coming to rest if it is noted that after 3.0 s its speed has dropped to half its original value? Assume that the drag force of the water is proportional to v.
...anyone?
The equation of motion would be
[tex]\frac {dv}{dt} = -k v[/tex]
Can you integrate that?
Do I get lnv=-kt ? What do I need to do after I find what k is?
Whats the answer given in your reference book?
-Cheers.
The answer is 10m, and i have no idea how they got it
When you solve the differential eqn you will have 2 variables(1 from integration & other 'k')Use the initial conditions given to find them.
At t=0,v=? and one more.
Else,if you did definite integration ,you have to figure out k by the 2nd condition given.
[tex]v = v_0 e^{-kt}[/tex]
Since ln v=-kt+ C (you forgot to add the constant), v= Ce-kt which has two unknown parameters, C and k. Now use the information you were given: "traveling at a speed of 2.4 m/s shuts off its engines at t = 0". Okay, when t=0, v= Ce-k(0)= C= 2.4. "it is noted that after 3.0 s its speed has dropped to half its original value" Okay, when t= 0, v= "half its original value" which is 2.4/2= 1.2 m/s. v= 2.4e-k(3)= 1.2 . Solve that for k.
