A pressurized can of sprayPaint
  • Context: Undergrad
  • Thread starter Thread starter vmars316
The discussion revolves around the physics of a pressurized can of spray paint, focusing on the thermal effects observed when gas is released from the can. Participants explore concepts related to gas expansion, cooling, and potential heating of the nozzle, as well as connections to similar phenomena in air conditioning systems.
  • One participant inquires about the heating and cooling effects observed when gas is released from a spray can, specifically asking which areas heat up and which cool down.
  • Another participant suggests that the cooling effect is due to a decrease in fluid density and references Boyle's law for further understanding.
  • A participant notes that while the can itself cools down, they question whether other parts, like the nozzle, heat up during the process.
  • It is proposed that the gas requires energy to expand, leading to cooling of both the can and the surrounding air.
  • One participant discusses the concept of adiabatic expansion, asserting that the gas cools upon release and suggesting that the nozzle may heat up due to friction with the gas molecules.
  • A comparison is drawn to air conditioning systems, where a similar cooling effect occurs as a gas expands and absorbs heat, with one participant asserting that the spray can undergoes a comparable process.
  • Another participant agrees that the nozzle dissipates energy but still cools down because the gas is cooler than the ambient temperature.
  • A participant provides a detailed explanation of Boyle's Law, outlining the relationship between pressure, volume, and temperature of gases, and how changes in one affect the others.
Participants express a range of views on the thermal dynamics of the spray can, with some agreeing on the cooling effects and others debating the extent and nature of heating at the nozzle. No consensus is reached on the specifics of which parts heat up or cool down and the mechanisms involved.
Some assumptions about the behavior of gases under pressure and the specific conditions of the spray can are not fully explored, leaving room for further clarification on the interactions between gas expansion, temperature changes, and friction effects.
vmars316
Greetings,
I would like to know the physics of a 'pressurized can of sprayPaint', or insecticide, etc..
When the gas is released: some area heats up, and another area cools off.
Could someone explain this to me. Or aim me at an article, with diagrams, that
will explain why and which?
Thanks...vmars316
Science news on Phys.org
The cooling off is because the density of the fluids inside the can is decreasing.
Try looking up "Boyle's law," it shoul dgive you Wiki articles and other links that will explain everything.
I've never noticed "certain parts" heating up; which parts? If it's near the nozzle, that may just be the friction of the ags and paint moving quickly through the nozzle.
[ "certain parts" heating up; which parts? ]
Holding the can while spraying:
the can itself gets cooler.
Does it get hot elsewhere? Nozzle? etc..
Thanks...vmars316
A gas thad is expanding needs energy or otherwise heat to make thad expansion possible.
So when the gas leaves the can it needs energy to expand and so it cools down the can itself as well as the air around the can.
correct me if i am wrong, the gas that is release actually cools down (adiabatic expansion of gas) and the nozzle of the can (the hole which the gas escapes) heats up due to friction between the nozzle and gas molecules.
This effect actually happens in an Air Conditioner. The coolant is compressed and cooled, which causes it to liquify. Then it passes through an evaporator and a portion of the coolant changes to a gas once the pressure drops, causing the rest of the coolant to cool further and keeping it in a liquid state. Then this liquid/gas coolant reaches the coil and absorbs heat from the intake, cooling the air and causing the coolant to completely evaporate into a gas state. That gas gets compressed and cooled again and the cycle repeats.
I think that the spray can goes through the same effect.
The heating of the nozzle wouldn't be noticeable in everyday life, but I think it would happen.
The nozzle will dissipate some of the energy from the gas moving through it, but it will still cool down because the gas is cooler than the ambient temperature.
* I found a pretty good answer here:
http://www.math.montana.edu/frankw/ccp/before-calculus/function/boyle/learn.htm
Boyle's Law involves a relationship between three properties of a gas in a container.
The volume of the container -- denoted V. Volume is measured in units of length^3 -- for example, cubic centimeters or cubic inches.
The pressure of the gas -- denoted P. Pressure is measured in units of force per area -- for example, pounds per square inch.
The temperature of the gas -- denoted T. Temperature is in many ways more complicated than pressure or volume.
It is usually measured using one of three units -- degrees Fahrenheit, degrees Celsius, or degrees Kelvin.
Boyle's Law states
PV = kT
where k is a constant, or
Pressure * Volume = Constant * Temperature
The value of the constant k depends on the units used for
the other quantities but once the units are fixed, k is also fixed.
When anyone of the quantities V, P, or T is changed,
one or two of the others must change so that the equation above still holds.
Thanks...vmars
  • · Replies 109 ·
10K
  • · Replies 18 ·
  • · Replies 28 ·
