People say there is weightlessnes
  • Context: Undergrad
  • Thread starter Thread starter ShayanJ
The discussion revolves around the concept of weightlessness, particularly in the context of orbiting space stations and elevators. Participants explore explanations based on inertia, gravitational forces, and normal forces, examining how these concepts relate to the sensation of weightlessness in different scenarios.
  • One participant proposes that weightlessness in a space station is due to inertia, suggesting that the station's acceleration causes a perceived lack of force acting on the body.
  • Another participant challenges this explanation, arguing that both the station and the occupants experience the same gravitational force, which leads to a shared velocity and the sensation of weightlessness.
  • A different explanation is introduced, stating that weight is felt due to the normal force exerted by a surface, and when this support is removed, such as in free fall, the sensation of weight disappears.
  • Participants discuss the analogy of an elevator, noting that the normal force changes when the elevator accelerates downwards, leading to a reduced sensation of weight.
  • Questions arise regarding why normal force varies with motion parallel to it, linking back to the initial discussion about weight and gravitational effects.
Participants express differing views on the nature of weightlessness and the role of inertia and gravitational forces. There is no consensus on the explanations provided, and the discussion remains unresolved with competing interpretations.
Some explanations rely on specific interpretations of gravitational forces and normal forces, which may depend on the definitions used. The discussion includes assumptions about motion and forces that are not universally agreed upon.
ShayanJ
Insights Author
People say there is weightlessness when you get far a little from earth.But we as people who are familiar with phyiscs know that its not true.I've thought about it and found an explanation(prefered to think my own instead of searching for it) based on inertia and I think there is a similar effect when we're in an elevator.But now I'm having troubles with my explanation which takes me in doubt if its right or not.This is my explanation:
imagine we're in an space station which is orbiting earth.The station is experiencing a gravitational force caused by Earth's mass which gives it an acceleration.So our station is accelerated toward earth.We should move with it too but because of inertia,we tend to preserve our last velocity every moment.So at every point of time,our velocity is a bit less than station's velocity and this causes us to feel an imaginary acceleration in the opposite direction of gravitational acceleration and so it looks like that no force is being applied to us which we call weightlessness.
I want to ask you that is this correct?
Your explanation is a bit jumbled, so I think you might still be missing a few points, but you're on the right track, at least.
There are a number of ways to explain micro-gravity on an orbital station, but the general idea is this. What you really experience as weight is not so much the gravity but the force applied by the surface that supports you. Gravity acts on all points of your body the same way, and so if nothing was there to prevent them from accelerating, there would be no net strain on your body due to gravity. However, if something prevents your feet from accelerating downwards, e.g. floor, then your feet are preventing the bones in your legs from accelerating downwards, which support the rest of your skeleton, which supports the flesh, and so on. It's the strain on the structure due to the fact that there is a pull of gravity, yet it is prevented from accelerating that is actually experienced as weight.
As soon as you remove the support, that strain goes away. The station accelerates at the same rate as people on the station, so nothing blocks the acceleration of the persons, and that means they experience no weight.A completely different way to look at it is to consider coordinate system rotating with the station. Then you have centrifugal force, the centrifugal force balances the gravity perfectly, and the net force on everything is zero. But this explanation you have to be careful with, as it involves an accelerated frame of reference.
There is also an explanation due to General Relativity which basically says that there is no such thing as force of gravity. But that's a bit more complicated.
Let's bring the example to an elevator.Imagine its going down.We feel less strain which means the force that the surface of elevator applies to us is less than the one when its not moving.So we should say that the normal force of elevator's surface is decreased because of its downward motion.I think this is a good explanation becasue when elevator moves upward we feel more strain.
But another question arises.Why the normal force changes due to motions parallel to it?
It takes me back to the explanatin I gave in the first post because normal force depends on weight.
No, this is not true. The change in velocity due to a force is instantaneous.
If it were true that "our velocity is a bit less than the station's velocity", we would eventually slam into the station wall. Both we and the station start with the same velocity and, since we have the same force applied to us, we always have the same[/b\] velocity as the station- that's we feel "weightless".
  • · Replies 18 ·
  • · Replies 30 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 48 ·
