New Reply
estimation of reflected electron beam power falling on a target
Share Thread Thread Tools
Dec1-10, 12:58 AM   #1
Hi,
I need to calculate an estimate of the reflected electron beam power in the form of back scattered electrons and secondary electron emissions from a tungsten/Graphite target. The Electron source is a 25kV source with operated at a power of around 25kW. The tungsten. graphite blocks are 50mm x 30mm and is 15mm thick. the heat produced from the surface is extracted by a water cooling system which runs through the tungsten block, below the 15mm thick layer of tungsten.
How do i approach such a problem? how do you calculate the total energy absorbed in the target, the amount reflected?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Dec6-10, 03:46 AM   #2
Hi,
Look at www.mc-set.com, where you can download a program to calculate BS electrons from an electron beam, such as the one in a scanning electron microscope.
From that, you can extend to your particular case.
Best regards,
Eli
Dec7-10, 12:04 PM   #3
At 1 amp on the target, the backscattered electrons may cause a significant space charge problem. This would lead to defocusing of the incident beam.
Bob S
New Reply
Tags
backscattered, beam, electron, reflected power
Thread Tools
Similar Threads for: estimation of reflected electron beam power falling on a target
Thread Forum Replies
Target area, collimated beam Introductory Physics Homework 3
Power Series Estimation/Error Problem Calculus & Beyond Homework 1
Fixed Target vs Colliding Beam experiment Introductory Physics Homework 0
Beam target fussion probability plot High Energy, Nuclear, Particle Physics 0
Sizing a beam to withstand falling objects. General Engineering 7
