Jordan basis and jordan normal form
  • Thread starter Thread starter specialnlovin
    Basis Form Normal
The discussion revolves around finding the Jordan basis and Jordan normal form of a given matrix A, with a characteristic polynomial of (x-1)³(x-2). Participants are exploring the minimal polynomial and the implications of eigenvalues and their multiplicities in relation to Jordan blocks.
  • Participants discuss the eigenvalues and their algebraic multiplicities, questioning the sizes of the Jordan blocks associated with these eigenvalues. There are attempts to clarify the minimal polynomial and to determine the eigenspaces and eigenvectors.
The conversation is active, with participants providing insights into the structure of the Jordan normal form and the relationship between the minimal polynomial and the sizes of Jordan blocks. Some participants are questioning the correctness of previously stated eigenspaces and eigenvectors, indicating ongoing exploration of the topic.
There are indications of confusion regarding the minimal polynomial and the calculation of eigenvectors, with references to specific calculations needed to determine the Jordan basis. Participants are encouraged to verify their results and explore additional resources for clarification.
specialnlovin
Let
A=
PHP:
2 -1 2 1
1 0 3 1
-2 1 0 1
-1 0 0 3
the characteristic polynomial of A is (x-1)3(x-2)
find the minimal polynomial, jordan basis, and jordan normal form
I know the minimum polynomial is (x-1)(x-2), but I am not sure how to find the nordan basis and jordan normal form
The eigenvalues are 1 and 2.
The algebraic multiplicities of the eigenvalues tells how many times each eigenvalues there are on the diagonal. Here, the number 1 will appear 3 times on our diagonal and the number 2 will appear 1 time on our diagonal.
Now, the most important thing is the size and the numbers of the Jordan blocks.
The size of the largest Jordan block of an eigenvalue, is the exponent of this eigenvalue in the minimal polynomial. So, in our example here, what are the sizes of the largest Jordan blocks of the eigenvalues 1 and 2??
so the largest sizes of the jordan blocks for 1 and 2 are 1x1 blocks
Indeed. But this means that the Jordan normal form is a diagonal matrix! And in particular, the matrix is diagonizable!
Thus the Jordan normal form can easily be written down.
The Jordan basis is, in this case, just the basis for diagonalization (i.e. a basis of eigenvectors)
how do we find the basis of eigenvectors though? when i did (A-I) i got only one vector
First determine the eigenspaces of 1 and 2.
so is the eigenspace of 1 the span of (2, 3, 0, 1)t? and the eigenspace of 2 the span of (1, 1, 1, 1)t? but then how do i get the eigenvectors from that?
Hmm, I recalculated. It seems your minimal polynomial is wrong. It is not true that
[tex](A-I)(A-2I)=0[/tex]
What is the correct minimal polynomial??
(a-i)3(a-2i)
For V1(1) i found the vector v1=(2, 3, 0, 1)T
for V2(1) i found the vector v2=(-1, -1, 1 0)T
but I cannot figure out v3
Ok, so the correct minimal polynomail is [tex](x-1)^3(x-2)[/tex].
So, what are the sizes of the largest Jordan blocks of 1 and 2?
the largest jordan block of 1 is 3x3 and 2 is 1x1.
so the eigenspace of 1 is the span ((2, 3, 0, 1)T, (-1, -1, 1, 0)T, (0, 1, 0, 0)T)
and the eigenspace of 2 is the span of (1, 1, 1, 1)T right?
No these eigenspaces are incorrect. The vectors you mention aren't even eigenvectors...
The next step you need to do is to determine bases for
[tex]Ker(A-I), Ker[(A-I)^2], Ker[(A-I)^3], Ker(A-2I)[/tex]
This will help us determine the Jordan basis.
If you're confused about what I'm doing. Check the following site www.ms.uky.edu/~lee/amspekulin/jordan_canonical_form.pdf This gives some examples of calculations of the Jordan normal form...
