Electromarnetisem/ Magnetohydronamics
  • Thread starter Thread starter leoflindall
The discussion focuses on a problem in magnetohydrodynamics involving plane-parallel, non-magnetic single fluid flow in the z direction. The key equation to demonstrate is \(\frac{P_{1}}{\rho_{1}} = \frac{5P_{0}}{3\rho_{0}}\), where \(P_{0}\) and \(\rho_{0}\) represent the pressure and density of the uniform background. The relevant equations include the mass conservation equation and a constraining equation that relates pressure and velocity. The user seeks guidance on how to approach the problem, indicating a connection between the conservation of mass and the constraining equation.
  • Understanding of magnetohydrodynamics principles
  • Familiarity with fluid dynamics equations
  • Knowledge of partial differential equations
  • Proficiency in LaTeX for mathematical notation
  • Study the derivation of the mass conservation equation in fluid dynamics
  • Research the application of the constraining equation in magnetohydrodynamics
  • Learn about the implications of pressure and density fluctuations in fluid flow
  • Explore advanced topics in magnetohydrodynamics, such as wave propagation in fluids
Students and researchers in fluid dynamics, particularly those focusing on magnetohydrodynamics, as well as anyone tackling complex fluid flow problems involving pressure and density relationships.
leoflindall
Consider plane-parrallel, non magnetic single fluid flow in the z direction. Assume that the realtionship between pressure, velocity and density is constrained by equation (3), shown below.
Show that
[tex]\frac{P_{1}}{\rho_{1}}[/tex] = [tex]\frac{5P_{0}}{3\rho_{0}}[/tex]
Where
P[tex]_{0}[/tex] and [tex]\rho_{0}[/tex]
are the pressure and density of the uniform background on which a wave with small pressure and density fluctiations of
P[tex]_{1}[/tex] and [tex]\rho_{1}[/tex] propagates in the z direction.
(1) [tex]\frac{d\rho}{dt}[/tex] + [tex]\frac{d}{dz}[/tex] ([tex]\rho[/tex] v) = 0
(Mass Conversation)
(2) v = vz^
(3) [tex]\frac{d}{dt}[/tex] [ [tex]\frac{1}{2}[/tex] [tex]\rho[/tex]v[tex]^{2}[/tex] + [tex]\frac{3}{2}[/tex]P ] + [tex]\frac{d}{dz}[/tex] [v([tex]\frac{1}{2}[/tex] [tex]\rho[/tex] v[tex]^{2}[/tex] + [tex]\frac{5}{2}[/tex] P )] = 0
(The Constraining equation)
Please note where the notation [tex]\frac{d}{dt/dz}[/tex] has been used to indicate the partial differential (I'm not the best at Latex!)
I'm not looking for an answer to this problem. This a set problem that I have been set, and am at a loss at how to tackle it. I can the see there is a realtionship between the conservation of mass equation and the constraining equation, however I can't see how to tackle it to show what is required.
Any thoughts of hints inthe right direction would be greatly appreciated.
Many Thanks
Leo
Solved.
Thank you for viewing.
  • · Replies 32 ·
