Register to reply
Won't Compile the simplest of programs! Am I being stupid?
by JamesWMH
Tags: c++, compile, fortran, program, programming
Share this thread:
JamesWMH
#1
Dec2-10, 06:05 PM
P: 3
Hi, I'm just getting my teeth back into Fortran 90 I had a course on it last year, and just want to familirise myself with it before I apply for post grad stuff.
Anyway, the program i have written is:
program emosix
real:: a, roota
write(*,*) 'Type an interger to find the square root (must be a positive number)'
read(*,*) a
if(a>=0.0)
stop
roota = sqrt(a)
write(*,*) 'The sqaure root of ', a, ' = ', roota
pause
end program emosix
and I get the error code:
Error: Cannot assign to a named constant at (1)
C:\Users\James\Documents\Programming\Emo6\~emo6.f90:15.5:
pause
Warning: Deleted feature: PAUSE statement at (1)
The warning about deleted feature hasn't made any difference in the past, so I don't think its that, but I have no idea what the cannot assign... part means?? Any ideas?
Thanks Jim
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
Mark44
#2
Dec2-10, 08:09 PM
Mentor
P: 21,215
Why is that stop in there after the if statement?
Also, your if statement needs an end if, I believe.
program emosix
real:: a, roota
read(*,*) a
if(a>=0.0) then
  roota = sqrt(a)
  pause
end if
stop
end program emosix
JamesWMH
#3
Dec2-10, 08:37 PM
P: 3
Hi
Thanks for the response, its in there to stop the program if the user puts a negative number in, as you can't have a square root of negative number.
I put in the end if and it gives me another error
if(a>=0.0)
C:\Users\James\Documents\Programming\Emo6\~emo6.f90:11.3:
end if
Error: Expecting END PROGRAM statement at (1)
C:\Users\James\Documents\Programming\Emo6\~emo6.f90:17.5:
pause
that is what I get now.
JamesWMH
#4
Dec2-10, 08:39 PM
P: 3
oops its supposed to be 'a<=0.0' but that didn't change anything.
Thanks
Jim
Mark44
#5
Dec3-10, 11:04 AM
Mentor
P: 21,215
Quote Quote by JamesWMH View Post
Hi
Well, you can, but the result won't be real. Instead of stopping the program, you should have logic that prevents the program from attempting to take the square root of a negative number.
if(a>=0.0)
end if
pause
You can take the square root of 0, so you should make the test expression a < 0.0.
As far as the "can't assign to a named constant" business, try using a different variable for roota.
What does your code look like now? You if statement wasn't formed correctly before, and it still might not be right.
jtbell
#6
Dec3-10, 11:26 AM
Mentor
jtbell's Avatar
P: 11,619
if(a>=0.0)
You need a "then". For example (also fixing your test condition):
      if (a <= 0.0) then
         stop
      end if
For some reason, the missing "then" triggers the "can't assign to a named constant" error.
Mark44
#7
Dec3-10, 01:08 PM
Mentor
P: 21,215
Quote Quote by jtbell View Post
You need a "then".
I added one in the code I showed in post #2, but didn't say that explicitly. I should have, since the OP seems to have missed it.
      if (a <= 0.0) then
         stop
      end if
The condition can be written as a < 0.0.
anoopak99
#8
Sep24-11, 09:12 AM
P: 2
suggestion of mark is absolutely correct
the error is coming due to absence of THEN statement
thanx
uart
#9
Sep25-11, 07:53 AM
Sci Advisor
P: 2,751
I know this is an old thread that's been bumped for some reason, but I would like to add one more thing.
The Fortran "if" statement doesn't require a "then" (or an "endif" either) when the "if" is only controlling a single statement.
In this sense the OP's code should (almost) have worked correctly, had he not put the "new line" after the "if" statement (since end of line is more than just white space in Fortran source code).
   if (a <= 0.0) stop
This should have worked correctly without "then" and without "endif"
Register to reply
Related Discussions
Help! can not compile package with f77 Programming & Computer Science 29
Compile pgs for cygwin Math & Science Software 0
The following C++ program does not compile Programming & Computer Science 2
JAVA: Why won't it compile? Programming & Computer Science 3
