My confusion with IgE antibodies and allergy?
The discussion revolves around the role of IgE antibodies in allergic reactions, particularly in the context of bee stings. Participants explore the mechanisms of allergic responses, the involvement of different antibodies like IgA, and the physiological effects of histamine release during such reactions.
  • One participant questions why a bee sting is considered an allergic reaction on the first exposure, suggesting that IgE antibodies should only mediate reactions upon subsequent exposures.
  • Another participant agrees that allergic reactions typically occur after the second exposure and clarifies that IgA is not involved in bee stings due to its role in mucosal immunity.
  • A later reply elaborates on the function of IgA, noting its presence in body surfaces and questioning its absence in allergic reactions, while also discussing the specific roles of IgE in triggering mast cells and basophils to release histamine.
  • Further details are provided about the contrasting effects of histamine in different body systems, particularly in the respiratory system versus systemic circulation.
Participants generally agree on the role of IgE in allergic reactions and the specific function of IgA, but there is some uncertainty regarding the timing and mechanisms of allergic responses, particularly in relation to first-time exposures.
There are limitations in the discussion regarding the assumptions about the timing of allergic reactions and the specific roles of different antibodies, which remain unresolved.
sameeralord
Hello everyone,
There was a simple question given, where there was a bee sting on a guy and the question asked was what is the antibody involved. The answer is IgE. Now my question is when there is bee sting for the first time, why do we called it an allergic reaction. I mean for an allergy to occur don't we have to be exposed to the antigen second time, so IgE attached to Mast cells will release histamine 2nd time. Also why aren't other antibodies like IgA ect not involed in a bee sting. Thanks :smile:
Biology news on Phys.org
You are correct, the allergic reaction only occurs after the second sting and due to presence of IgE antibodies. IgA is not involved in this because it functions in mucosal immunity.
Hey thanks for help Jack :smile: I have a quick clarification though. IgA protects body surfaces. It is synthesized by secretory epithelial cells. So it should be found in skin. Is the reason it is not involved is because it protects against microorganisms and IgE against allergens.
Yea kind of. Remember that immunoglobulins are 3d things that bind to different stuff. IgE mostly has impacts on mast cells and basophils and incite them to release their granules (degranulation). Mast cells and basophils contain granules with histamine and heprain (probably the two most important components anyway) which cause "allergic" reactions.
Specifically in the respiratory system (which just make matters confusing for you, the respiratory system has opposite reactions of the systemic parts of the body) histamine causes vasoconstriction. Which makes sense if you think about it from your bodies point of view. If you are breathing "something bad" the body wants to restrict the air inflow to those parts of the tracheobronchial tree, restricting intake of the irritant. The problem occurs when too much histamine is released and you have global (relative to the lung) vasoconstriction which restricts total air flow. In the systemic parts of the body (the nose for instance), histamine causes vasodialation and increased secretions. Again, makes sense from your body's POV. If you have a pathogen invading the nose, you want more blood flow (increases the availability of leukocytes) and more mucous to "flush" the pathogen out.
Secretory IgA (~10% of our IgA) is produced by plasma cells which constitutively secrete IgA which is then transported across the mucosal epithelium and out of the body (via bodily secretions) and mostly aids in interference of bacterial pathogenesis or assists in opsonization (searchable term) of pathogens.
17K
  • · Replies 18 ·
