Is the Curl of This Vector Field Zero?
The discussion revolves around the vector field F = -ysin(x)i + cos(x)j and the application of the curl test to determine properties of the field.
  • Conceptual clarification, Mathematical reasoning
  • Participants explore the definition and application of the "curl test," with some seeking clarification on its meaning and implications. There is an inquiry into the ability to compute the curl of the given vector field and what can be inferred from its value.
The conversation is ongoing, with participants questioning the definition of the curl test and discussing its relevance to the vector field in question. Some guidance has been provided regarding the implications of a zero curl, but there is no consensus on the specific facts that can be deduced.
Participants are tasked with deducing three facts about the vector field after applying the curl test, which may imply certain constraints or expectations regarding the depth of analysis required.
mathwizeguy
F=-ysin(x)i+cos(x)j
Can the Curl test be applied to this vector field and state three facts you can deduce after applying the curl test.
What exactly do you mean by "curl test"?
the curl test is a test to find if a vector field is path independent by taking the partial derivative of F1 and F2 of a function F with respect to x, for F2, and with respect to y, for F1.
Basically I am havin trouble finding 3 facts to incur about this F after the curl test.
Are you able to find the curl of this vector field?
In general, if the curl of a vector field is zero, that means that (a) it's the gradient of a scalar (potential) function; and (b) the line integral of scalar potential function is path-independent.
