| New Reply |
Reverse Induction? |
Share Thread | Thread Tools |
| Dec6-10, 12:54 PM | #1 |
Reverse Induction?
Say I had a problem like this: Prove that the nth derivative of x*e^(x) is (x+n)*e^(x) for all integer n. Can I use reverse induction to prove for negative n? For example... Say I proved it for my base case, n=0. In this case, the proof is trivial. Then I prove that if the nth derivative is (x+n)e^(x), then the (n+1)th derivative is (x+n+1)e^(x). (I didn't provide the proof because there's a similar homework problem here, and the proof is easy anyway. Can I then use reverse induction to prove that if the nth derivative is (x+n)e^(x), then the (n-1)th derivative is (x+n-1)e^(x), thus extending this case to negative derivatives (i.e., integrals)? Am I even making sense? |
| Dec6-10, 05:02 PM | #2 |
Hmm, I'm not sure if this is correct. You do have to use reverse induction though. But isn't it easier to show "if it holds for -n, then it holds for -n-1". Or is this what you meant?
| Dec6-10, 05:03 PM | #3 |
| New Reply |
| Thread Tools | |
Similar Threads for: Reverse Induction?
| Java Reverse | Engineering, Comp Sci, & Technology Homework | 4 | ||
| Is there some reverse of annihilation? | Quantum Physics | 7 | ||
| Difference between Strong Induction and Mathematical Induction? | Calculus & Beyond Homework | 5 | ||
| Reverse the number | Programming & Comp Sci | 0 | ||
| reverse FFT | Electrical Engineering | 1 | ||
