Solve Pendulum Motion & Period of Oscillation: Mass M, m, x, l
  • Thread starter Thread starter nathangrand
    Pendulum
The discussion revolves around the motion of a pendulum used as a timing element in a mechanical clock. The original poster presents the equations of motion for a pendulum with a bob of mass M and explores the effects of attaching a smaller mass m at a distance x from the pivot on the period of oscillation.
  • The original poster attempts to derive the period of oscillation for both the simple pendulum and the modified pendulum with an additional mass. They express uncertainty about how to determine the position x that maximizes the influence of the smaller mass on the period T0, considering differentiation as a potential approach.
Some participants provide guidance on focusing on the expression for the period without the square root to simplify the differentiation process. The original poster has attempted differentiation and derived a quadratic equation, leading to a potential solution for x. However, there is no explicit consensus on the correctness of this solution yet.
Participants are working under the assumption that the mass m is much smaller than M, which influences their approach to the problem. There is also a focus on the mathematical manipulation of the derived expressions for the period of oscillation.
nathangrand
A light rigid pendulum of length l with a bob of mass M is to be used as the
timing element of a mechanical clock. Write down the equation of motion for the
system and hence determine the period of oscillation T. A second mass m is now attached to the pendulum arm at a distance x from the pivot, where 0 < x < l. Obtain an expression for the new period of oscillation T0. Assuming that the mass m is much smaller than M, determine the position
x at which it exerts its greatest infuence on the period T0.
For first part got d''(theta)/dt^2 (g/l)theta =0
which gives T=2Pi*SQRT(L/g)
For second part get equation d''(theta)/dt^2 + theta(Mgl + mgx)/(mx^2 + Ml^2) = 0
and T0 of 2pi* SQRT((mx^2 + Ml^2)/(Mgl + mgx))
I have no real idea though how to find the value for x at which the small mass has the largest influence on T0...thought about differentiating something perhaps?
hi nathangrand! welcome to pf! :smile:
(have a square-root: √ and a theta: θ and a pi: π and try using the X2 icon just above the Reply box :wink:)
you want to find the greatest effect of that square-root, of the form √(Ax2 + B)/(Cx + D) …
so forget the square-root, and deal with (Ax2 + B)/(Cx + D) on its own :wink:
Ok..I have done this and differentiated it with respect to x to get :
mx^2 + 2MLx - ML^2 = 0
with a bit of messing around with the quadratic formula I get x=L/2 is this right??
hi nathangrand! :wink:
without seeing your full calculations, i can't check,
but L/2 is certainly the answer i'd have guessed! :smile:
  • · Replies 20 ·
