Effects of a 10^60 Decrease in Solar Photon Energy on Earth's Temperature
  • Context: Graduate
  • Thread starter Thread starter bhsmith
    Energy Photon
A decrease in solar photon energy by a factor of 10^60 would result in the sun emitting approximately 10^-44W, rendering it effectively a black body. This drastic reduction would eliminate the Earth's primary energy source, leading to a significant drop in temperature over time. Initially, the atmosphere would retain some heat, but eventually, Earth would transform into a barren wasteland. The extinction of life would occur gradually, particularly affecting organisms reliant on sunlight, while some geothermal-dependent life forms may survive longer.
  • Understanding of solar luminosity and its impact on planetary climates.
  • Basic knowledge of thermodynamics and heat transfer principles.
  • Familiarity with the concept of black body radiation.
  • Awareness of Earth's atmospheric effects on temperature regulation.
  • Research the implications of solar luminosity changes on planetary atmospheres.
  • Study the principles of black body radiation and its relevance to astrophysics.
  • Explore thermodynamic models of heat retention in planetary atmospheres.
  • Investigate extremophiles and their survival mechanisms in geothermal environments.
Astronomers, climate scientists, and anyone interested in the long-term effects of solar energy fluctuations on Earth's environment and life sustainability.
bhsmith
What would happen if the Energy of the photons from the sun decreased by 10^60?
I think it means that the Earth would be colder than it is because the sun is not emmiting as much heat, but I'm not sure if that is correct. Thanks for any help!
A factor of 10^60 decrease in the energy output of the sun would make it basically a completely black ball. The solar luminosity is something like 10^26W, so dividing that by 10^60 gets you some ridiculously small number like 10^-44W...
The Earth would no longer have an external energy source, and would cool down to very frigid temperatures. It takes a little bit of time for this to happen though because the Earth has an atmosphere which traps heat, but after a couple of...days or weeks (I'm not sure how long it would actually take), the Earth would be a baron wasteland.
I think such a sudden reduction in output without having burned through its store of nuclear fuel would result in a sudden collapse, nova, and re-ignition... every part of which which kill us. Matterwave's answer is as good as any. I would suspect that it would take a great deal of time for all life to die, at least those stranger forms that seem to eschew sunlight and live on geothermal processes.
  • · Replies 38 ·
  • · Replies 0 ·
  • · Replies 23 ·
  • · Replies 58 ·
  • · Replies 46 ·
