Frequency Doubling: Typical Conversion, Input Power & CW Laser?
  • Context: Graduate
  • Thread starter Thread starter Thermodave
    Frequency
The discussion centers on the efficiency of frequency doubling methods, particularly in the context of converting 1064 nm light to 532 nm. Participants explore the typical conversion rates, the influence of input power on efficiency, and the applicability of these methods to continuous wave (CW) lasers.
  • One participant seeks to understand the typical efficiency of frequency doubling from 1064 nm to 532 nm, noting a wide range of reported efficiencies from 0.01% to over 50%.
  • Another participant explains that frequency doubling is a second-order process in nonlinear optics, with efficiency increasing quadratically with the amplitude of the incoming light field.
  • It is mentioned that the efficiency of second harmonic generation (SHG) is highly dependent on the nonlinear crystal used and the specific wavelengths involved, with some crystals achieving around 20% efficiency for certain wavelengths.
  • Higher peak powers are noted to generally allow for higher efficiencies, although they may introduce other complications.
  • A participant expresses interest in the potential for efficient frequency doubling of low-power CW lasers, particularly in the context of absorption experiments using diode lasers.
  • There is a suggestion that the availability of efficient doubling methods could expand the range of usable wavelengths for experiments.
Participants express varying views on the efficiency of frequency doubling methods and the impact of input power, with no consensus reached on specific values or methods. The discussion remains unresolved regarding the best approaches for low-power CW lasers.
The discussion highlights limitations related to the dependence on specific nonlinear crystals and the conditions under which frequency doubling is most effective, particularly for low input powers and continuous wave lasers.
Thermodave
I'm trying to get an idea of how efficient frequency doubling methods are. I quick google search gives back everything from .01% to above 50%. What is the typical conversion from 1064 to 532? Is this common for other wavelengths/crystals? More importantly, why does it sound like the efficiency is related to input power? Can low power cw laser be doubled? Thanks for any info.
In nonlinear optics you develop the response P to a light field of amplitude E in a power series of the field amplitude:
[tex]P(t)=\chi^{(1)} E(t) +\chi^{(2)}E^2 (t) +\chi^{(3)}E^3 (t)+...[/tex]
Second harmonic generation/frequency doubling is a second order process and therefore proportional to the square of the amplitude of the incoming field. Therefore its efficiency increases also quadratically with the amplitude.
The efficiency also depends strongly on what nonlinear crystal you use and which wavelength you are aiming at. There are good crystals cut for 800nm->400nm achieving up to 20% efficiency. I am sure the record values are way higher, but not representative.
As a consequence SHG works best for short pulses. SHG for cw is of course also possible but not very effective, even worse for low input powers. What input power and wavelength are you considering exactly?
Higher peak powers generally allow higher efficiencies. But they can also give rise to other issues.
Thank you for the explanation. I wasn't thinking a specific experiment though. I've just noticed that there are a lot of diode lasers (e.g. New Focus 25mW cw) models on the market now with narrow linewidths that can be used for absorption experiments but that they are all in the red. If there was an efficient doubling approach than I'm sure we'd be seeing a broader range of wavelengths. Doing absorption spec in the 300s would be convenient, if it was tunable of course.
  • · Replies 30 ·
