Temperature and Entropy of an ideal gas
The discussion centers on the thermodynamic behavior of one mole of an ideal gas during adiabatic and isothermal expansions. For the adiabatic expansion into a 200L container, the final temperature can be determined using the first law of thermodynamics, specifically the equation ΔU = nC_vΔT. In the case of isothermal expansion, the change in entropy can be calculated by integrating dQ/T over the reversible path, where dQ represents the heat exchanged during the process.
  • Understanding of the first law of thermodynamics
  • Knowledge of ideal gas laws and properties
  • Familiarity with adiabatic and isothermal processes
  • Ability to perform thermodynamic calculations involving internal energy and entropy
  • Study the first law of thermodynamics in detail
  • Learn about adiabatic and isothermal processes in ideal gases
  • Explore the derivation of entropy change for isothermal processes
  • Review specific heat capacities (C_v and C_p) for ideal gases
Students studying thermodynamics, particularly those tackling problems related to ideal gases, as well as educators looking for examples of adiabatic and isothermal processes.
moonkey
One mole of an ideal gas is confined to a vessel of volume 4L at a temperature of 300°C. The vessel is placed inside a container of volume 200L and the gas is released.
(a) What is the final temperature of the gas if it's expansion into the container is adiabatic?
(b) What would be the change in entropy if the expansion were isothermal?
Not worth showing. I've been at this question and four others for more than 10hours over the last two days and I only have one of them done. I'd appreciate any helpful hints.
do you know what the relevant equations are?
If you do, then you can quite easily solve the problem knowing
v1, t1, v2...you can find t2.
Start by answering these questions (assume the 200L container is empty to start):
1. Does the gas do any work in expanding into the 200L space?
2. Apply the first law. If there is no heat flow (adiabatic) what is the change in internal energy? That will give you the change in temperature: [itex]\Delta U = nC_v\Delta T[/itex]
3. To calculate the change in entropy you have to determine integral of dQ/T over the reversible path between the beginning and end state. In the reversible path, the gas would maintain constant temperature but it would be doing work. So what is the expression for dQ?
AM
  • · Replies 67 ·
  • · Replies 33 ·
