Solving Plate Capacitor Problem with Voltage U
The discussion focuses on solving the plate capacitor problem with an applied voltage U, involving two plates with surface area F and distance d apart, along with a conducting plate of charge Q between them. The capacitance is calculated using the formula C = (ε * F) / d, where ε represents the permittivity of the medium. The relationship between electric field E, potential U, and distance d is defined as E = U / d. The presence of the charged conductor modifies the electric field, creating different values above and below the conductor due to its influence on the electric field lines.
  • Understanding of capacitance formulas, specifically C = (ε * area) / distance
  • Knowledge of electric field concepts, particularly E = (potential) / (distance)
  • Familiarity with the behavior of charged conductors in electric fields
  • Basic principles of electrostatics and charge distribution
  • Study the effects of dielectric materials on capacitance and electric fields
  • Learn about the superposition principle in electrostatics
  • Explore the concept of electric field lines and their behavior around conductors
  • Investigate the applications of capacitors in circuits involving AC and DC voltages
Students and professionals in electrical engineering, physics enthusiasts, and anyone studying electrostatics and capacitor behavior in electric fields.
galipop
Hi All,
I've been doing a few problems with plate capactors and I have this new one which introduces a voltage U. I haven't seen an example with a voltage befopre so I'm not sure where to start it. I'm hoping someone could start me off.
The problem goes like this: Find the electric field between the plates when a voltage U is applied to the cap. The cap consists of 2 plates (surface area F, distance d apart). Between the plates is a conducting plate of charge Q.
Thanks...
THe capacitance is found as (epsilon)(area)/(distance). Also capacitance is defined as the ratio of (charge)/(potential). Lastly the relationship with the electric field is E=(potential)/(distance).
I think (someone check me on this) The charged conductor in between the plates will add to the electric field of the capacitor,(in the manner of an infinite charged plane) so there will be a different value for the field above and below this conductor, since it will add on one side and subtract on the other.
  • · Replies 18 ·
