Electric field strength due to two point charges
The discussion focuses on calculating and plotting the electric field strength due to two point charges, +1 x 10^-6 C and +3 x 10^-6 C, positioned 10 cm apart. The electric field strength at a point 4 cm from the first charge is calculated using Coulomb's law, yielding a value of 562.5 N/C directed towards the second charge. Additionally, at a midpoint of 5 cm from each charge, the electric field strength is calculated to be 2400 N/C, directed towards the first charge. The electric field strength decreases with distance from the charges and approaches zero at greater distances.
  • Coulomb's law for electric fields
  • Understanding of electric field strength calculations
  • Basic knowledge of point charges and their interactions
  • Familiarity with the concept of electric field direction
  • Study the application of Coulomb's law in different charge configurations
  • Learn about electric field lines and their representation
  • Explore the concept of superposition in electric fields
  • Investigate the effects of distance on electric field strength
Students in physics, electrical engineers, and anyone interested in understanding electric fields and their behavior in the presence of multiple point charges.
stunner5000pt
Given are two charges +1 X 10^-6 and one 3 X 10 ^ -6 distnace of 10 cm apart
I know there is a poitn in between these two and it is 4 cm from the 1.0 X 10^-6 charge
But i am asked to plot the elctric field strength as a function
if the elctric field is pointing right, then positive, otherwise if poitning left, then negative
Let what happens on the outside of these two charges be, i can figure that on my own
But what happen in the middle
Point at 4 cm and rises after??
Negative
3.66 cm, you mean? (It is not 4.00 cm for sure so I assume you rounded off)
Negative
I hope you only have to roughly sketch the result because it's not a simple function to draw at all. But it starts at + infinity near the left charge, decreases sharply, crosses into the negative values as you pass the 3.66 cm mark (assuming the left charge is the 1 microcoulomb), goes down and approaches -infinity near the right charge.
Unfortunately, I have to leave (it's midnight here and I am still in my office. And I am teaching tomorrow at 8h30!).
Good luck with your questions!
Pat
(-) | 4 cm | (+)
The electric field strength at the point 4 cm from the +1 X 10^-6 charge and 6 cm from the +3 X 10^-6 charge can be calculated using the formula:
E = k*q/r^2
Where:
E - electric field strength
k - Coulomb's constant (9x10^9 Nm^2/C^2)
q - charge of the point charge
r - distance between the point charge and the point at which the electric field is being measured
In this case, the electric field at the point 4 cm from the +1 X 10^-6 charge and 6 cm from the +3 X 10^-6 charge can be calculated as:
E = (9x10^9 Nm^2/C^2) * (1 X 10^-6 C) / (0.04 m)^2 = 562.5 N/C
Since the two charges are of opposite signs, the electric field at this point will be directed towards the +3 X 10^-6 charge, making it positive. This means that the electric field strength is pointing to the right.
On the other hand, if we consider a point between the two charges, for example at 5 cm from the +1 X 10^-6 charge and 5 cm from the +3 X 10^-6 charge, the electric field strength can be calculated as:
E = (9x10^9 Nm^2/C^2) * (1 X 10^-6 C + 3 X 10^-6 C) / (0.05 m)^2 = 2400 N/C
Since the two charges are of the same sign, the electric field at this point will be directed towards the +1 X 10^-6 charge, making it negative. This means that the electric field strength is pointing to the left.
In general, the electric field strength will decrease as we move away from the charges and will depend on the distance and the magnitude of the charges. At points further away from the charges, the electric field strength will approach zero.
