Find Closed Form of Differential Equation: y''' - y = 0
The discussion revolves around finding the closed form of a power series that is a solution to the differential equation y''' - y = 0. The power series in question is given as ∑_{n=0}^{∞} (x^{3n}) / (3n)!. Participants are exploring methods to derive the closed form and discussing the implications of the series being a solution to the differential equation.
  • Participants have attempted differentiating the power series and applying it to the differential equation but encountered difficulties. There are suggestions to consider characteristic polynomials as an alternative method. Some participants are questioning how the series relates to the exponential function and what that implies for the solution.
The discussion is ongoing, with participants sharing their attempts and seeking further guidance. Some have noted that the power series resembles the series for e^x, prompting questions about the relationship between the two. There is acknowledgment that C*e^x may be part of the solution, but the need to find all solutions is emphasized.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. The original poster expresses uncertainty about their approach and seeks additional hints or tips to progress.
fittipaldi
Hi, everyone, I need some help with the following:
Given is, that the following power series:
[tex]\sum_{n=0}^{\infty} \frac{x^{3n}}{(3n)!}[/tex]
is the solution to the following differential equation: y''' - y = 0. Find the closed form of the series.
None
Well I tried differentiating the sum, then applying it to the differential equation, but I get something very nasty, so I am sure, I am on a bad way.
Please, help!
None
Please, help!
Well, you're given that that particular series is a solution to y''' - y = 0. You can also solve this another way. Might I recommend characteristic polynomials?
(also, doesn't that power series look suspiciously close to the power series for e^x?)
That is true, but I cannot seem to understand how to continue ... a bigger tip maybe?
Also noticed that, the only difference is the coefficient. C*e^x is also one of the solutions to the given equation, how does this help?
Well, it's entirely possible that the closed form of your power series is C*e^x for some C. In fact, it looks like that's the case to me.
EDIT: After checking, I can conclude that C*e^x is PART of the solution. However, you'll need to find ALL solutions to the differential equation. C*e^x is just one.
hi fittipaldi! :smile:
as Char. Limit :smile: says, use the characteristic polynomial :wink:
  • · Replies 27 ·
