Acid, Base, and Buffer Titration Problem
The discussion centers on calculating the moles of acetic acid (HC2H3O2) in a buffer solution containing 0.300 moles of sodium acetate (NaC2H3O2) and a measured pH of 4.40. The pKa of acetic acid is 4.76, and using the Henderson-Hasselbalch equation, the solution reveals that 0.131 moles of acetic acid were present. The total moles of acetic acid and sodium acetate in the solution amount to 0.43 moles. The discussion emphasizes the importance of simplifying assumptions in buffer calculations, particularly neglecting acetic acid dissociation and base hydrolysis.
  • Understanding of the Henderson-Hasselbalch equation
  • Knowledge of acid-base dissociation constants (Ka and Kb)
  • Familiarity with buffer solutions and their components
  • Basic skills in logarithmic calculations
  • Study the Henderson-Hasselbalch equation in detail
  • Learn about buffer capacity and its implications in chemical solutions
  • Explore the concept of acid-base equilibrium and dissociation
  • Investigate common laboratory techniques for measuring pH and preparing buffer solutions
Chemistry students, educators, laboratory technicians, and anyone involved in acid-base chemistry and buffer solution preparation.
MitsuShai
I missed this question on an exam and I was wondering if anyone can explain to me how to do it.
The pKa of acetic acid, HC2H3O2, is 4.76. A buffer solution was made using an unspecified amount of acetic acid and 0.300 moles of NaC2H3O2 in enough water to make 2 Liters of solution. Its pH was measured as 4.40 on a meter. How many moles of HC2H3O2 were used?
K= [products]/[reactions]
pH= pKa + log (A/HA)
Ka= 10^(-4.76) = 1.74 x 10 ^(-5)
Kb = 5.75 x 10^(-10)
pH =4.4 [H]=3.98 x 10^(-5)
pOH= 9.6 [OH]= 2.51 x 10^(-10)
moles of OH= 2.51 x 10^(-10) x 2= 5.02 x 10^(-10) moles
Base_________+____H2O -->___Acetic Acid_+_____OH +______Na
.3 moles______________________x_________________0
-5.024 x 10^(-10)__________5.02 x 10^(-10)_______5.02 x 10^(-10)
.2999 moles_______________x+ 5.02 x 10^(-10)______5.02 x 10^(-10)pH=pKa + log(A/HA)
4.4=4.76+ log (.3/(x+5.02 x 10^(-10)))
=10^-(-.36)= 10^[log (.3/(x+5.02 x 10^(-10)))]
2.29= .3/(x+5.02 x 10^(-10)))
(2.29)(x+5.02 x 10^(-10))=.3
x=.131 moles
.3 + .131= 0.43 moles
Most of what you did is irrelevant to the question, and to be honest - I don't plan to try to understand what you did and why. For some reason you decided to take into account base hydrolysis, but you ignored acetic acid dissociation (these both processes take place in the solution). But - and this is the most important hint at solving the problem - when doing buffer questions we usually ignore both dissociation and hydrolysis, assuming they are neglectable.
Start with HH equation, solve it for the concentration of acetic acid - and as you know volume of the solution, you are done.
