How to Approach an Op-Amp Homework Problem with Earthed Terminals?
The discussion revolves around an op-amp problem involving earthed terminals, focusing on understanding the behavior of ideal op-amps in circuits with negative feedback. Participants are exploring the implications of input voltages and current flow through resistors in the circuit.
  • Participants discuss the characteristics of ideal op-amps, particularly the conditions under which no current flows into the input terminals and the implications of negative feedback on input voltages. Questions arise regarding the setup of equations and the relationship between the input voltages.
There is an ongoing exploration of the relationship between the input voltages and the current through the resistors. Some participants are questioning the assumptions about voltage equality at the input terminals, while others are attempting to clarify the implications of negative feedback in the circuit.
Participants are navigating the complexities of an op-amp circuit where one input is tied to a fixed voltage, leading to confusion about the expected voltage at the other input terminal. There is a recognition of the high gain of the op-amp and its effect on output behavior.
thereddevils
See attachment.
I am not familiar with questions like this. The usual op-amp i see have either of the terminals earthed so i need some hints to get started. Thanks.
Hint: The important things to remember about the (ideal) op-amp is that
1. No current flows into or out of the input terminals.
2. In a negative feedback situation, both input terminals will always be at the same voltage (no voltage difference).
That being the case, what can you say about the voltage at the (-) input?
How about the current in the resistors?
Thanks Gneill for your reply.
Ok, since the input impedance of the op-amp is very high, the current flowing through the 20 k ohm resistor is the same as the one through the 100 k ohm resistor.
I am not sure about point 2. Why are the voltage of the input terminals the same? How do i set up the equations? V- = 8V and V+ = 4V ??
Good.
8V is not the same as 4V.
Because the op-amp has very high gain (infinite for the ideal op-amp), any difference in voltage between the V- and V+ input terminals would be magnified infinitely at the output terminal. In practical terms, the output would swing towards one of the power supply rails.
This doesn't happen in a properly configured amplifier circuit with feedback, because the feedback path acts to keep the differential voltage at zero. Thus V- = V+. In your circuit, one of the inputs is tied to a fixed voltage supply. What should you conclude?
I understand this.
The difference between V+ and V- is zero if connected with a negative feedback resistor? Is V- = 8V and V+ = 4V? I am still confused with the potential difference across the positive and negative input terminals.
What's to be confused about? For an ideal op-amp in a circuit with negative feedback, the difference is zero. 8V and 4V is not a difference of zero volts, it's a difference of 4 volts.
Set the difference between the inputs to zero. One of the inputs is tied to +4v by a fixed supply voltage. What must the voltage at the other input terminal be?
What a miss!
Obviously, the voltage of the upper input terminal is 4V and having the same current flow,
(8-4)/20k = (4-Vo)/100k
Vo=-16V
Am i right?
Bravo!
gneill said:
Bravo!
Thanks for all the help! Cheers.
  • · Replies 22 ·
  • · Replies 23 ·
  • · Replies 27 ·
