Gallium spoons - how does the human body metabolize gallium?
The discussion centers on the metabolism of gallium (Ga) in the human body, highlighting its low toxicity but cautioning against ingestion. Gallium melts at 29.7646 °C, meaning it can liquefy in the mouth or stomach and react with stomach acid (HCl). It is not an essential micronutrient, and its interaction with biological processes is similar to that of iron(III), raising concerns about potential health implications. The cost of pure gallium is approximately USD 100 per gram, suggesting that gallium spoons may be alloys or electroplated rather than pure gallium.
  • Understanding of gallium properties and its melting point (29.7646 °C)
  • Basic knowledge of human metabolism and micronutrients
  • Familiarity with chemical reactions involving acids, particularly hydrochloric acid (HCl)
  • Awareness of Material Safety Data Sheets (MSDS) and their implications
  • Research the biological effects of gallium ions on human health
  • Investigate the applications of gallium salts in medical research
  • Learn about the safety and handling of gallium and its alloys
  • Explore the chemical properties and reactions of gallium with acids
This discussion is beneficial for chemists, health professionals, and anyone considering the use of gallium in culinary applications or its implications for human health.
bizzder
hi there, i came across this video https://www.youtube.com/watch?v=kIbYiO5BRYk http://www.youtube.com/watch?v=kIbYiO5BRYk, and before I buy the set I'd like to know how the human body metabolized gallium metal/ions. I've read quite extensively on gallium metal, but I can't find much info on how the body processes gallium. Does anyone have sprecific info on this? what will happen if an amount is swallowed; how much is dissolved in the stomach? thanx!
Biology news on Phys.org
"Gallium (Ga) is associated with a relatively low toxicity, but should be handled with care until more health data has been accumulated."
This is from an old MSDS (Material Data Safety Sheet) floating around here. I believe this is still correct. It does not give me personally the warm fuzzies about using a soft metal (chemists call it a poor metal) as a spoon. Pure Ga will melt in hot food and then react with acids in food. 29.7646 °C is the melting point. This means it will melt in your stomach or your mouth. It will also react slowly with stomach acid (HCl).
Gallium is not known to be an essential micronutrient. So there is earthly reason to ingest it. Even in extremely small quantities. Or flavor your food with it, for that matter.
Metabolic handling of gallium(III) as though it were iron(III), the gallium ion can interact with many processes in the body in which iron(III) particpates. I do not think you want Ga-based hemoglobin in your red blood cells, for example.
See this for an applications of Ga salts in medical research:
http://www.ncbi.nlm.nih.gov/pubmed/18475921
The other point is that pure Ga sells for ~USD100 per gram. I cannot view the video but I think this whole deal sounds fishy, to say the least. I am assuming these spoons are a Ga alloy of some sort, or the spoon would be unuable as a spoon for hot food, else it must have Ga electroplating(?). Otherwise the cost would be astronomical.
30K
18K
  • · Replies 28 ·
130K
