Temperature neutralization of explosives
  • Thread starter Thread starter GRB 080319B
    Temperature
The controlled burn conducted by San Marcos Fire Chief Todd Newman reached temperatures between 1,500 to 1,800 degrees Fahrenheit, effectively neutralizing the dangerous chemicals present in the condemned house without causing a catastrophic explosion. Many explosives can burn rather than detonate, requiring a specific shock wave to initiate an explosion, which high temperatures alone do not provide. While some explosives did ignite, they did not detonate in a coordinated manner. The sensitivity of various high explosive compounds to heat, friction, and shock varies significantly, complicating generalizations about their behavior under extreme temperatures.
  • Understanding of explosive chemistry and properties
  • Knowledge of thermal dynamics and combustion processes
  • Familiarity with controlled burn techniques in hazardous material management
  • Awareness of safety protocols in explosive handling
  • Research the chemical properties of common high explosives
  • Study the principles of thermal decomposition of explosives
  • Learn about controlled burn methodologies for hazardous materials
  • Investigate the role of shock waves in explosive detonation
This discussion is beneficial for explosive ordnance disposal (EOD) technicians, fire safety professionals, and anyone involved in hazardous material management and neutralization techniques.
GRB 080319B
With respect to the http://www.kusi.com/story/13646760/bomb-factory-house-leveled-by-controlled-fire?redirected=true", why do high temperatures neutralize explosives instead of setting them off?
The controlled burn resulted in temperatures of 1,500 to 1,800 degrees inside the condemned house, enough heat enough to neutralize all the dangerous chemicals stashed and strewn throughout, said San Marcos Fire Chief Todd Newman, one of the supervisors of the operation.
Chemistry news on Phys.org
Many explosives are can burn instead of explode - they need something that will start detonation. High temperature is not enough, as it doesn't create necessary shock wave.
The fire did set off some of the explosives--there were reports of a few pops. However, it looks like they didn't go off in any organized way. Also, Borek is correct: many "high explosive" compounds are employed for their lack of sensitivity. The sensititivity to friction, shock, and heat varies from compound to compound though, so it's hard to make generalizations as to why the house didn't explode without knowing what kinds of explosives were in there.
  • · Replies 16 ·
  • · Replies 36 ·
11K
  • Sticky
507K
