Is This Equation Correct? p² = p₀² + 2mΔk
  • Context: Graduate
  • Thread starter Thread starter Superstring
The discussion revolves around the equation p² = p₀² + 2mΔk, which relates momentum and kinetic energy. Participants explore its derivation, validity, and potential applications, touching on theoretical and conceptual aspects.
  • One participant presents a derivation of the equation, suggesting it is correct and seeking validation from others.
  • Another participant references a relationship between momentum and kinetic energy, proposing an alternative expression involving changes in kinetic energy.
  • A different participant simplifies the expression for Δk, indicating a straightforward approach to relate kinetic energy and momentum.
  • One participant confirms the dimensional validity of the equation while questioning its practical application.
  • Another participant notes that the equation holds true for speeds much smaller than the speed of light.
  • A participant discusses the utility of the equation in solving for mass more simply compared to a system of equations involving momentum and kinetic energy.
Participants express varying degrees of confidence in the equation's correctness, with some supporting its validity and others providing alternative perspectives. The discussion does not reach a consensus on the equation's application or necessity.
Some assumptions regarding the conditions under which the equation is valid are not explicitly stated, and there are unresolved questions about its practical applications.
This discussion may be of interest to those studying mechanics, particularly in relation to momentum and kinetic energy, as well as individuals exploring the derivation and application of physical equations.
Superstring
[tex]p^2=p_0^2+2m \Delta k[/tex]
I derived it using the following:
[tex]k=\frac{1}{2}mv^2[/tex]
[tex]p=mv[/tex]
[tex]\frac{dk}{dv}=mv=p[/tex]
[tex]\frac{dp}{dv}=m[/tex]
[tex]\frac{dk}{p}=dv[/tex]
[tex]\frac{dp}{m}=dv[/tex]
[tex]\frac{dk}{p}=\frac{dp}{m}[/tex]
[tex]mdk=pdp[/tex]
[tex]\int_{k_0}^{k}mdk=\int_{p_0}^{p}pdp[/tex]
[tex]m\Delta k=\frac{1}{2}(p^2-p_0^2)[/tex]
As far as I can tell it's correct, but I though I'd get a second opinion.
Since p2 = 2mk, where k = ½mv2
mk = ½p2
m (k2 - k1) = ½(p22 - p12)
Bob S
Isn't it easier to just note this?
[tex]\Delta k = k - k_0 = \frac{p^2}{2m} - \frac{p_0^2}{2m}[/tex]
Edit: Ninja'd.
As well as what Bob S mentioned, I would say your equation is dimensionally valid.
By the way, why you need such an equation? Or what is it mainly used for?
It's correct for speeds much smaller than that of light.
Thanks for the responses :).
As far as uses, it's a great deal simpler to solve for the mass than if you were to use a 3-equation system with p=mv, p0=mv0, and Δk=(m/2)(v2-v02) if you were only given p, p0 and Δk.
  • · Replies 27 ·
  • · Replies 18 ·
