Is Biot-Savart's Law Consistent with Early Physics Principles?
  • Context: Graduate
  • Thread starter Thread starter vishureddy
    Law
The discussion revolves around the historical and conceptual foundations of Biot-Savart's Law, particularly its consistency with earlier principles of physics. Participants explore the assumptions made by Biot and Savart regarding the relationship between magnetic fields and electric currents, as well as the methods used to measure these quantities before the establishment of modern electrical concepts.
  • Historical
  • One participant questions why Biot and Savart assumed a proportional relationship between magnetic fields and current, given the historical context of measurement techniques.
  • Another participant suggests that early measurements may have been based on experimental relationships rather than theoretical foundations, indicating a reliance on intuitive insights from practical experimentation.
  • A different viewpoint explains that the unit of current was defined in terms of the magnetic force between two wires, and magnetic fields were measured using compass deflections, establishing a relative measure against Earth's magnetic field.
  • One participant argues that the magnetic field is fundamentally defined by the currents that produce it, suggesting that the relationship is more about empirical observation leading to definitions rather than the other way around.
Participants express differing views on the historical assumptions and definitions related to Biot-Savart's Law. There is no clear consensus on whether the law is consistent with earlier physics principles, and the discussion remains unresolved regarding the implications of these historical measurements and definitions.
Participants highlight limitations in understanding the historical context of measurements and definitions of magnetic fields and currents, as well as the potential for circular reasoning in the use of instruments like ammeters.
vishureddy
Why Biot and Savarat assumed that magnetic field due to a current carrying wire is proportional to current ?
How did they measure the current in those days when even ohms law was not discovered?
If they have used an instrument like an ammeter there is a problem with it .An ammeter works on an assumption that the deflection of the coil in it is proportional to current which in turn is proportional to magnetic field .How can we use this assumption to define the magnetic field around a wire?
What are the first definitions given to magnetic field and current?
And my last doubt is
is biot savarats law consistent with laws in laws in physics that are established before it?
thanks a lot in advance for clarifying the doubts
Can't answer the history aspects...but try here and see if Amperes and Gausses laws were instrumental...
http://en.wikipedia.org/wiki/Biot-Savart_law
Maybe the relationships were measured experimentally rather than based on some esoteric theory, but I really don't know...Often people who did lots of early experiments had intuitive insights from experience and tested them and gradually formed a "law" that we take for granted today...
To prove that magnetic field is proportional to current associated with the wire, we have to measure the magnetic field and current. At that time it was tricky. They defined unit of current in terms of magnetic force between 2 straight wires.(ampere). Magnetic field can be measured by placing a compass near current carrying wire and moving it towards and away and noting its deflection from magnetic field lines of earth.so if we take Earth's field is 1 unit, then we measure field strength of wire relative to it.
Note:(from griffiths electrodynamics)
Permeability of free space serves to define an ampere and ampere in turn defines coulomb.
I think you may be going about this backwards. The electric and magnetic fields are force fields. They are used to describe the forces between sources, charges and currents. This is no different than with gravitational fields. When we have two masses in proximity then they experience a force due to each other. Now we can describe this force purely as a relationship between the two (F = G*m1*m2/r^2) or we can say that one mass creates a gravity field (Grav_Field = G*m1/r^2) and this field causes a force on any mass in its presence, where F = Grav_Field*m.
This is of course a trivial example but it is no different than the electric field between two charges.
So static charges experience a force that we can describe by a field we call the electric field. Currents experience a force that we can describe by a field we call the magnetic field.
So the magnetic field is produced by and is proportional to currents simply by definition. I think it is probably more accurate to say that the force between two currents was observed and out of this came the magnetic field as opposed to the opposite. It would then be a question of empirical observation and experimentation to determine how to describe the magnetic force (and its field) in terms of current, position, direction, etc. But once these rules were established (or at least the proportionality of the force with respect to current) then the ammeter would naturally come about.
