Is cleaning my coffee carafe necessary for better tasting coffee?
  • Thread starter Thread starter Integral
    clean
The discussion revolves around the necessity of cleaning coffee carafes and its impact on the taste of coffee. Participants share personal experiences and varying practices regarding the cleaning of coffee-making equipment, including carafes, pots, and espresso machines.
  • Some participants suggest that cleaning the coffee carafe is essential to avoid a muddy taste in coffee, citing personal experiences with buildup affecting flavor.
  • Others argue that they do not clean their coffee equipment regularly, relying instead on rinsing or minimal cleaning, and express uncertainty about the impact on taste.
  • A participant mentions a traditional method of making coffee that involves not cleaning the kettle, suggesting that the buildup may enhance flavor for some.
  • Some participants highlight the role of hard water in affecting coffee taste, indicating that cleaning is prompted by noticeable changes in flavor.
  • There are differing opinions on the necessity of cleaning based on personal preferences for coffee taste, with some expressing a preference for instant coffee due to its convenience and lower energy use compared to brewed coffee.
  • Concerns are raised about rancid oils and lime buildup affecting coffee taste, with some participants advocating for regular cleaning practices.
  • One participant humorously notes the time-consuming nature of cleaning and preparing coffee, suggesting instant coffee as a simpler alternative.
Participants do not reach a consensus on whether cleaning is necessary for better-tasting coffee. Multiple competing views exist regarding cleaning practices and their effects on flavor.
Some participants mention specific cleaning methods, such as using vinegar or soap, while others express limitations in their cleaning routines due to the design of their coffee equipment. The discussion reflects a variety of personal habits and preferences without resolving the debate on cleaning necessity.
Do you clean your coffee pot?
  • Total voters
    30
Integral
Staff Emeritus
I have been watching the coffee patina grow inside my carafe for years, it was a rich brown. Yesterday my wife looked inside and claimed to understand why our coffee was tasting muddy. She made me clean it back down to shiny stainless.
So the question is, to clean or not to clean?
I have an espresso machine and I don't clean it. I rinse out my mug with hot water every morning. NO soap or scouring.
I can't stand anything that even vaguely tastes like coffee, so forgive me for asking this.
Why don't you clean your cup, or mug, or pot, or whatever?
Yes , but only if I am going to use it to brew up some nectar for the hummingbirds. I do it when my wife isn't home. Then when she comes home she says: "Oh how sweet you cleaned out the coffee maker."o:)
Eventually the carafe gets cleaned.
We use drip coffee makers, so the carafe or pot is glass.
With the hard water around here, it doesn't take long before you can notice a less tasty cup. Which is my cue to clean.
The proper way to make coffee was taught to me by a Norwegian.
* Get an old-style iron kettle, designed for use on a fire or gas/electric stove. Do NOT attempt to use an electric kettle.
* Put a layer of coarse ground coffee in the kettle.
* Fill with cold water.
* Heat slowly till it boils (this should take about 20-30 minutes).
* Pour the hot liquid, unfiltered, into coffee mug, add sugar and/or cold milk to taste.
* Enjoy.
Warning: until you get acustomed to it, this is a very effective laxative!
The kettle must NEVER be cleaned. If you run out of coffee, just fill the kettle with water and simmer for a longer time.
Did the coffee improve after the cleaning?
How did you clean it, btw?
I clean my stailess steel coffee pot every other month. I scour the pot with a brillo after cleaning the coffee maker with a vinegar solution. After which I run two pots of water through the coffee making cycle to rinse it. The first pot after that is usually not, shall I say, "The " but it's better than Dunkin or the option at work.
Not to my taste. Of course I drink it black while the wife's is about 50% milk + flavoring, so how would I know :rolleyes:
I have a stainless vacumn carafe. I cannot get my hand inside, my wife just can but there are very sharp tabs sticking out which slice at her wrists.
I used a large kitchen spoon and a scruber sponge.
I have always just rinsed out the old coffee, making no effort to scrub.
I remember when I was in the navy someone took the effort to clean our coffee urn, about half the shop was up in arms about lossing the patina. I really don't know if it makes any difference, but being a bit lazy I usually take the easy route! :blushing:
Do you clean your pots and pans after cooking with them? I don't really see the difference.
I clean glass, non-stick, and stainless. With LIGHT soap only, Iron and ceramics Don't get washed with soap and no abrasives. Ok. Like the South Park kids getting their money back from Mel Gibson... Some level of purity and dedication is required!
typically run white vinegar through the machine twice, then twice more with water to clean it.
I will fill the stove kettle with 1:1 water:vinegar and bring it to a boil for a few minutes to remove the hard water deposits.
If you don't clean it the oils that have adhered to the caraffe become rancid, lime bilds up, these things will give a bad taste to your coffee, unless you've developed a taste for tainted coffee.
I clean it on a semi-regular basis... my spouse wouldn't ever clean it.
This also appears to be the case with the bathrooms in the house.:eek:
Cleaning a coffee pot and even preparing coffee is a time consuming process so use instant coffee as opposed to brewed coffee because brewed coffee must be brewed in coffee brewers which use 900W of power on average regardless of whether the brewer uses fire or electricity. The brewer must usually be operated for an hour causing it to use 900Wh of energy while the water used for instant coffee can simply be heated in a microwave which uses 800W of power on average for only 30 seconds before the coffee powder is mixed in causing it to use only 6.67Wh of energy which is 135 times lower than the energy used by the fire and electrical brewers.
...but instant coffee is disgusting.
The other advantage of instant coffee is that it maximizes the utilization of coffee cream powder and sugar because those two powders are pre-mixed into the instant coffee and the amount that is introduced into each batch is regulated by timed powder injectors. And if there is an error, feedback sensors would relay the information to the computers controlling the production process so that the saturated batches can be re-processed. In this way, the human error of simply estimating the sugar and cream quantity before introducing it to the coffee is eliminated from the preparation process which again maximizes the efficiency of coffee making. Some bottles are even equipped with spring loaded, push actuated trap valves that are timed to close the bottle cap after a certain amount of coffee powder is poured to ensure that just the right amount of powder is mixed in.
I actually find nothing wrong with instant coffee. The taste is fine to me and it provides the same kind of stimulant effect delivered by brewed coffee. I guess some people are just attached to the smell and feel of a coffee brewer.
This is my understanding also. I clean our drip glass carafe every weekend. Just lightly with soap and water with a wash rag.
Drinking just cold water is even more energy efficient.
You must have one hell of a coffee cup if you need a kw for an hour
Civilised societies use coffee presses which need to heat precisely the same amount of water as you do for instant coffee.
Plus instant coffee is made by basically making a cup (or tank) of proper coffee and then evaporating it - how much energy do you think that takes?
This is because I was not referring to a brewer for a single cup but a kettle sized brewer which serves about four cups but if the energy is divided, it takes at least 225Wh of energy to brew each cup, but compared to the 6.67Wh of energy used by the microwave, the microwave still uses 34 times less energy to prepare the coffee.
NobodySpecial said:
Civilised societies use coffee presses which need to heat precisely the same amount of water as you do for instant coffee. Plus instant coffee is made by basically making a cup (or tank) of proper coffee and then evaporating it - how much energy do you think that takes?
Actually, because the batch brewing and spray drying process is precisely controlled by automated systems and a variety of chemical processing systems, the efficiency of instant coffee production is higher than if a regular coffee brewer is used. Now they could install such accessories in coffee brewers but that would greatly increase the cost of purchasing the brewer which is why these systems are best suited for the mass production of instant coffee. The instant coffee also has a longer shelf life thanks to its dehydrated form and has a lower shipping weight and volume than ground coffee or beans which decreases the energy used to ship the coffee and the amount of coffee that expires in the groceries. This is the reason why the average cost efficacy of ground or bean coffee is 5c/g while the instant coffee costs only 3c/g which makes it 67% cheaper and this is without mention of the sugar and coffee cream powder bottles that have to be purchased separately if ground or bean coffee is used. The coffee brewer that people have to purchase alone has a penalty on resources because it takes energy and materials to make and distribute the appliance whose only use is coffee brewing. The cost of purchasing disposable coffee filters, and the energy and materials used to maintain the brewer which is the initial dilemma posted by the thread originator are also additional penalties.
One has to wonder how much energy is consumed in making that powder?
Did you factor in the environmental damage done by those chemicals.
1. You are way off topic. This is not a thread about energy consumption.
2. The concoction you are talking about sounds so discusting that you may as well save lots of energy and not even make in the first place.
What has this got to do with cleaning a coffee carafe?
Evo said:
If you don't clean it the oils that have adhered to the carafe become rancid, lime builds up, these things will give a bad taste to your coffee, unless you've developed a taste for tainted coffee.
Fortnightly we have very good water. It just a few days from the snow pack and springs of the Cascade mountains. We have used that carafe for nearly 10 yrs with NO mineral build up. Nor is there any mineral build up in the https://www.amazon.com/dp/B00006F2MI/?tag=pfamazon01-20 itself. It is a vacuum carafe so the coffee does not get cooked after brewing, ie no heat is applied to keep it warm.
I cannot taste any difference from pre clean to after clean. We are currently using cheap a$$ Costco beans, I may go get some good http://www.sivetzcoffee.com/" beans to see if they taste better. The difference is $5/lb vs $10/lb.
What's your water quality like the other 2 weeks of the month :-p?
OMG! I am still wearing my glasses today, and my vision aint all that. The spell checker usually know what I mean, guess it didn't correctly read my mind this time.
Obviously that should read FORTUNATLY!
Suppose I should but my contacts in?
If instant coffee is used then a coffee carafe is unnecessary.
Actually, because the batch brewing and spray drying processes are precisely controlled by automated systems and a variety of chemical processing systems, the efficiency of instant coffee production is higher than if a regular coffee brewer is used. Now it is possible to install such accessories in coffee brewers but that would greatly increase the cost of purchasing the brewer which is why these systems are best suited for the mass production of instant coffee. The instant coffee also has a longer shelf life thanks to its dehydrated form and has a lower shipping weight and volume than ground coffee or beans which decreases the energy used to ship the coffee and the amount of coffee that expires in the groceries. This is the reason why the average cost efficacy of ground or bean coffee is 1.59c/g while the instant coffee costs only 0.74c/g which makes it 115% cheaper and this is without mention of the sugar and coffee cream powder bottles that have to be purchased separately if ground or bean coffee is used. The coffee brewer that people have to purchase alone has a penalty on resources because it takes energy and materials to make and distribute the appliance whose only use is coffee brewing. The cost of purchasing disposable coffee filters, and the energy and materials used to maintain the brewer which is the initial dilemma posted by the thread originator are also additional penalties.
The two images below were taken from an online supermarket and it shows the prices per gram of both types of coffees:
[PLAIN]http://img263.imageshack.us/img263/8484/groundl.png
[PLAIN]http://img560.imageshack.us/img560/323/instant.png
In dollar terms, this equates to 1.59c/g for the ground coffee and 0.74c/g for the instant coffee which makes the instant coffee 115% cheaper than the ground coffee. In fact, even with the lowest average price posted for bean coffee at $5/lb which equates to 1.1c/g, the instant coffee still turns out to be 50% cheaper than the bean coffee.
Drink tea.
EDIT: Also to the poster above, instant coffee tastes ****. So no point in making it in the first place. Then you can save your 47p by not buying Tesco rubbish.
Never, never sporadically clean a coffee cup or brewer. This is a very bad idea, and will lead to psychological episodes of insatiation.
Every coffee maker and coffee cup develops it's own fauna and flora. These develop on their own to become key, and necessary flavor enhancers. My own flavor additive happens to be provided by pale gray fungus garden residing in the water reservoir.
  • · Replies 25 ·
  • · Replies 34 ·
10K
  • · Replies 287 ·
29K
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 24 ·
  • Poll Poll
