Question on energy in magnetic field.
The discussion revolves around the energy in magnetic fields, specifically in the context of inductors and their inductance as described in various electromagnetism texts. Participants explore the relationships between magnetic flux, inductance, and the work done in circuits with multiple inductors, addressing both theoretical and practical implications.
  • One participant references Griffiths' book to discuss the relationship between magnetic flux and inductance, proposing a formula for work done in a single loop inductor.
  • Another participant clarifies that the total effective surface area in the context of multiple turns of inductors should be considered as NA, not A alone.
  • Concerns are raised about the validity of combining work done across multiple inductors with different numbers of turns, suggesting that the integration approach may not hold in such cases.
  • One participant expresses confusion regarding the inclusion of the number of turns in the work formula, questioning its redundancy in the context of inductance.
  • Another participant discusses the general formula for magnetic energy density, asserting that it applies broadly to magnetic fields without regard to specific setups or configurations of inductors.
  • There is a mention of a free resource from MIT OCW that provides relevant information on electromagnetic fields and energy, which some participants find useful.
  • Several participants express uncertainty about the consistency of the equations presented, with some seeking clarification on specific points raised in earlier posts.
Participants exhibit a mix of agreement and disagreement, particularly regarding the application of formulas to multiple inductors with varying turns. Some express confidence in their interpretations, while others remain uncertain about the implications of the equations discussed.
Participants note that assumptions about uniformity in the number of turns and surface areas may not hold in all cases, which could affect the validity of certain equations. There is also a recognition that the derivation of energy formulas may depend on specific configurations of inductors.
This discussion may be useful for students and professionals in electrical engineering, physics, and related fields who are interested in the theoretical and practical aspects of magnetic fields and inductance.
yungman
I am referring to the book "Introduction to Electrodynamics" by Griffiths p317, Energy in magnetic field.
[tex]\Phi = \int_S \vec B \cdot d \vec a = \int_C \vec A \cdot d \vec l[/tex]
[tex]LI = \int_C \vec A \cdot d \vec l[/tex]
But the inductance in defined as the flux linkage divid by the current that create the flux or:
[tex]L = \frac {\Lambda}{I}[/tex]
If the inductor is N turn, [itex]\Lambda = N\Phi[/itex]
I want to verify according to the book that:
[tex]LI = \int_C \vec A \cdot d \vec l \Rightarrow W = \frac {1}{2} I \int_C \vec A \cdot d \vec l \Rightarrow W = \frac {1}{\mu_0}[\int_v B^2 d \tau - \int_S (\vec A X \vec B) \cdot d\vec a][/tex]
Only apply to a single loop inductor or a straight wire type that N=1. Because for multi turn N inductor, [itex]\Lambda = N\Phi[/itex]
The notation S under the integral sign denotes the TOTAL effective surface. If there are N turns of area A, then S corresponds to NA, not A alone.
Thanks for your help, I understand now about the different meaning between the physics books and engineering book. But I think I still spot one part that cannot be resolved. For multiple inductors structure that consists of M inductors linked together. The work done to put currents in all of the inductors is:
[tex]W_m = \frac 1 2 \sum_{k=1}^M \Delta I_k \Lambda_k = \frac 1 2 \sum_{k=1}^M N_k \int_{C_k} \vec A \cdot \vec J dv_k[/tex]
The book went on to combine all the M parts together give
[tex]W_m = \int_v B^2 dv[/tex]
As you can see this cannot be done if the inductors have different turns ie [itex]N_1[/itex] not equal to [itex]N_2[/itex] not equal to [itex]N_3[/itex] ...etc. You can integrate the loop, but not if they have different turns. So they equation must stop at:
[tex]W_m = \frac 1 2 \sum_{k=1}^M\; I_k \; \Lambda_k \;=\; \frac 1 2 \sum_{k=1}^M \sum_{j=1}^M [L_{jk} \; I_j\; I_k] \;\;\hbox { where }\;\; \Lambda_k = \sum_{j=1}^M N_j \; I_j \; L_{jk}\;[/tex]
Let me know I am right or not.
Thanks
Alan
yungman said:
[tex]W_m=\frac{1}{2}\sum_{k=1}^M N_k I_k \Lambda _k[/tex]
I don't get why there is [tex]N_k[/tex] here while it is already included in [tex]\Lambda _k[/tex]
By the way, which book were you referring to in post #3?
I type it wrong.
I use what I got from you this morning and modify the equations in the book to get this. Let's derive the formula:
[tex]W_m\;=\; \frac 1 2 \sum_{k=1}^M I_k \; \Lambda_k \;=\; \frac 1 2 \sum_{k=1}^M I_k \; N_k \;\Phi_k \;=\; \frac 1 2 \sum_{k=1}^M I_k \; N_k \; \sum_{j=1}^M \int_{S_k} \Vec B_j \cdot d\vec {S_k} \;=\; \frac 1 2 \sum_{j=1}^M \frac 1 2 \sum_{k=1}^M \mu I_j I_k N_j N_k S_k[/tex]
This formula is consistance with what the book gave in terms of self inductance and mutual inductance. Below is the formula derive from inductance, if you expand it out, it will become my formula above:
[tex]W_m\;=\; \frac 1 2 \sum_{j=1}^M \sum_{k=1}^M L_{jk}\;I_j \; I_k[/tex]
For example for two inductor of [itex]N_1 \;\hbox { and }\; N_2[/itex] turns coupling together, M=2:
[tex]W_m\;=\; \frac 1 2 \sum_{j=1}^2 \frac 1 2 \sum_{k=1}^2 \mu I_j I_k N_j N_k S_k \;=\; \frac 1 2 \mu I_1^2 N_1^2 S_1 \;+\; \frac 1 2 \mu I_1 \;I_2 N_1 \; N_2 S_2 \;+\;\frac 1 2 \mu I_1 \;I_2 N_1 \; N_2 S_1 \;+\; \frac 1 2 \mu I_2^2 N_2^2 S_2[/tex]
If [itex]S_1=S_2[/itex] then:
[tex]W_m\;=\; \frac 1 2 \mu I_1^2 N_1^2 S_1 \;+\; \mu I_1 \;I_2 N_1 \; N_2 S_2 \;+\; \frac 1 2 \mu I_2^2 N_2^2 S_2[/tex]
The book I am using is "Fields and Waves Electromagnetics" By David K Cheng. I have 8 EM books including Griffiths, Ulaby, Hyat & Buck, Popovic, Schwarz, Kraus and JD Jackson. This and Griffiths are the best. Cheng cover a lot of engineering EM, phasor, smith chart, transmission line, antenna, cavity. Griffiths is more on materals and retarded potential.
Anyway, I just don't see
[tex]Wm = \int_v B^2 dv[/tex]
contain the informations of number of turns of each individual inductors, the surface of each inductors etc. Unless the formulas assumes all surface are same, all turns are the same. That is a big assumption.
This is the reason I still resort back to the very primitive formula with the summation of individual inductor as shown in post #5.
For post #5: Is there any inconsistency?
For post #6: I think you should check the formula; I remember there is some constant. Anyway, no big deal.
The formula is true for magnetic field in general. I don't have the book by David Cheng, but there is another free book provided by MIT OCW namely Electromagnetic Fields and Energy, where you may find the relevant information. Check out page 12, chapter 11, section 11.3 of the book:
http://ocw.mit.edu/courses/electrical-engineering-and-computer-science/6-013-electromagnetics-and-applications-fall-2005/textbook-with-video-demonstrations/
The (3b) equation in the page shows the partial energy density contributed by magnetic component of the EM field in linear medium: [tex]w_m=\frac{1}{2}\mu H^2 = \frac{1}{2\mu}B^2[/tex] . The derivation of this equation, as you can see, is not deduced from the consideration of any set-up or inductors, but any general EM field (so EM waves are included). This is also how scientists work. I believe some engineers also work in this way; but sometimes they choose [tex]W_m=LI^2/2[/tex] for example for the ease of analyzing their application.
That means, this formula doesn't care about the set-up, e.g. how many inductors are there or whether they are coupling. This formula applies whenever there is magnetic field, either when the field is stored inside some set-up or when the field propagates as waves.
The number of turns, the dimensions (area & length), etc, of inductors in particular and storage devices in general are included in the volume in which you calculate the integral [tex]\int_V B^2dV[/tex]. Those parameters define the volume (and also the magnitude of B) in which the magnetic field is stored.
Hey Hikaru1221
Thanks for all your help. I have to spend some time read this material first.
What is the inconsistency in #5, that is very important for me...as an engineer?!:wink:
Important to all, I think.
So what is the inconsistency?
BTW, what is your background?
Obviously my background is engineer. I just want to cross into Physics in my old age!
:confused: :confused: :confused:
I guess I'm lost in some sort of confusion. I thought post #6 of yours backed up some point in post #5, so there should be some inconsistency, but I didn't find it.
About my background, I would say I'm neither engineer nor scientist :biggrin: I am a bit of scientist and a bit of engineer. Anyway I find it hard to define "I" :biggrin:
So #5 looks ok to you?
What do you do in your career then? Or what are you planning to do if you are a student.
It seems ok to me (Sorry, I haven't checked the math; anyway, the idea behind the equations seems ok :wink:)
I'm college student, so I'm currently unemployed :biggrin: I'm studying Electrical Engineering.
Good for you, enjoy life while in school. You'll have your chance to slave for the next 30 years. I put in my time already, I am studying for enjoyment. Most of the engineers I talked to were so afraid of EM! THey all said they just want to get pass that however which way. I finish PDE, plan to study complex analysis and maybe enroll in the post grad electrodynamic classes in the future.
Thanks for you help. What EM book are you using? Take a look at Cheng's book, I have 8 and this one clearly the best for engineer. Go very deep into phasor, transmission lines, smith chart. From that you can get into designing filters, matching networks with distributed elements. I spent a lot of time doing that kind of design and simulations. Cheng's book is as good as Griffiths for scientist, these are the two must have for EM. They really compliment each other. I would say they are about 50% cross over.
I'm still in my first year in college, so I haven't taken EM course yet. Anyway, Cheng's book is the compulsory one for engineering EM course in my university, so I'll definitely go through it, hopefully next semester. Thank you for the advice :smile: and warning :rolleyes:
First year??!:rolleyes: How can it be? You are answering question on this EM stuff! And you are in the other MIT professor thread!
What university you going? Cheng's book is on the difficult side for undergrad. I have seen easier books. The one used by San Jose State is a much easier version of this. I actually looked into the advanced electromagnetic course offer in Santa Clara university ( which is consider a good school) , They are using Hyat and Buck which is no more difficulty than Cheng's book, and that one is lousy. I think you would enjoy Cheng's book. Get the Griffiths book also, it will answer a lot of questions you have on Cheng's book. This is because Cheng tried not to go into the physics side and move a little fast on the beginning part and go much more detail in field and wave. The two really compliment each other. You seems to be very interested in EM and you sure know a lot, you should keep at it. I heard so many people afraid of EM and they just craw through it!
Where did you learn at the EM stuff, can't be from the freshman physics! You need to know at very minimum vector calculus and differential equation to really understand it. I actually studied partial differential equation and now re-study the whole thing again plus the Griffiths book.
I found design distributed element transmission line circuit very interesting and that is the part of EM I am strong at. I design multipole filters, matching networks using just traces on pc board. If you look at the circuit board, it just has a pattern of traces looking like a maze and very few capacitors and resistors. This is all done after you study Cheng's book on transmission lines and smith chart, then you get into microwave design and get deeper into this kind. I use to have a lot of fun designing these stuffs.
Good luck on your study.
Alan
I find the connection between #8 and #9 hilarious :smile:
I must say that he is a genius in physics. The level of knowledge he has in Physics Subject is far greater than most of the lecturers at introductory level.
The derivation by Griffiths is a bit handwavy as I recall. The final formula is, as pointed out earlier in the thread, a general statement about the energy contained in a magnetic field. The derivation is restricted to the one-loop case though. I haven't seen it myself, but I think Wangsness derives the formula in a more general way in "Electromagnetic Fields". The result is the same obviously, but I think the reasoning is more general.
I don't really know what's true for a loop with N turns, but isn't it true then that [tex]N\Phi = LI[/tex]?
Therefore, shouldn't one simly replace [tex]\int_C \mathbf{A} \cdot d \mathbf{l}[/tex] with [tex]LI/N[/tex], and not [tex]LI[/tex], as is done in Griffiths derivation?
  • · Replies 32 ·
