Estimating Laser Force: The Relationship Between Photon Momentum and Light Power
  • Context: Graduate
  • Thread starter Thread starter azaharak
    Force Momentum Photon
The discussion revolves around estimating the force exerted by a laser based on the momentum of photons and their relationship to light power. Participants explore various methods of calculating this force, considering factors such as absorption and reflection of light, and the implications of these factors on the overall momentum transfer. The scope includes theoretical considerations and practical implications of laser force estimation.
  • One participant suggests estimating the force from a 5mW laser using the formula Power = Force * Velocity, acknowledging that this method is not entirely correct but may provide a rough estimate.
  • Another participant agrees that the approach could work if the beam is absorbed, noting that the momentum of a photon is Energy/c, leading to a force calculation of Power/c.
  • A different viewpoint emphasizes that if there is reflection, the force doubles, and suggests that the actual pressure lies between values based on absorption and reflection rates.
  • One participant challenges the accuracy of the previous claims, stating that no surface is completely absorbing or reflecting, proposing a model where 50% absorption and 50% reflection is assumed to calculate force per photon.
  • Another participant clarifies that with 100% absorption, the momentum is E(pulse)/c, and with 100% reflection, it is 2E(pulse)/c, indicating that the actual momentum transferred will be between these two extremes.
  • One participant shares an anecdote about a Crookes' radiometer, illustrating the concept of photon momentum, but notes that the mechanism behind its operation is more complex than initially thought.
Participants express differing views on the accuracy of various methods for estimating laser force, with no consensus reached on a single approach. There is acknowledgment of the complexities involved in absorption and reflection, leading to multiple competing models for understanding photon momentum transfer.
Participants highlight limitations in their models, such as the assumptions regarding absorption and reflection rates, and the dependence on specific conditions like the angle of incidence. These factors contribute to the uncertainty in the calculations presented.
azaharak
Would it be reasonble to estimate the force delivered by a laser in the following way?
I was thinking of demonstrating that photons carry momentum by attempting to make a very light mass displace by imposing laser light on the object.
For a 5mW laser
5mW/Speed of light = force that laser light imposes.
I know that its not a correct way of analyzing the physics, but could it crudley be used to give an approximate value?
Thanks
Yes, that would do OK, assuming that the beam is absorbed by the body (instead of being reflected). But think of it this way. The momentum of a photon is Energy/c. Thus the momentum per second delivered by the beam is Power/c, which would be the effective force of the beam. (For more on this, look up "radiation pressure".)
If there is reflection, the force is twice as large, so if you don't know the exact absorption or reflection, you still have two strict values between which the actual pressure lies (you know the area of the light beam, so you can relate force and pressure). You can simply see this as an uncertainty.
www.gentec-eo.com
@ Dr lots
This won't give correct answer as nothing is completely absorbing or reflecting.
You may assume that it absorbs 50% and reflect 50%.
You can even find the force per photon by calculating energy of each photon (using wavelength)
you can also use this:
power, W=n x E (E= energy of photon)
momentum, p= h/(lambda) = hv/c = E/c
for all photons, p=nE/c = W/c
force, F = dp/dt
use this as you think how many are absorbed or reflected or even reflected at which angles!
* consider momentums perpendicular to surface!
If there is 100% absorption, the momentum is E(pulse)/c.
If there is 100% reflection, the momentum is 2E(pulse)/c.
In reality, the mass will be partly reflecting, and partly absorbing, so the momentum p transferred will strictly be between both values : E/c < p < 2E/c
(assuming perpendicular incidence of course).
http://maxwell.byu.edu/~spencerr/websumm122/node117.html
Unless you have a well equipped lab, I doubt you'll convincingly push anything with 5 mW though. You'd be better off with high energy laser pulses (on a mirrored membrane perhaps).
Not very helpful but nonetheless interesting in my opinion:
My high school physics teacher had a small vacuumed glass casing with a tiny metallic axle with three metallic wings, or rather sails on it inside the casing. If the casing was placed in sunlight, the contraption inside would start spinning purely from the momentum of the photons in sunlight. A clear indication of the fact the photons carry momentum.
That's a Crookes' radiometer (also called a 'Light Mill'). It's not radiation pressure making it turn, as was first thought, but something more subtle. See: http://math.ucr.edu/home/baez/physics/General/LightMill/light-mill.html"
  • · Replies 58 ·
  • · Replies 29 ·
  • · Replies 46 ·
