New Reply
Help with Transverse Wave Equation
Share Thread
Dec14-10, 06:41 PM   #1
Unhappy
Two vibrating sources emit waves in the same elastic medium. The first source has a frequency of 25 Hz, while the 2nd source's frequency is 75 Hz. Waves from the first source have a wavelength of 6.0 m. They reflect from a barrier back into the original medium, with an angle of reflection of 25 degrees. Waves from the second source refract into a different medium with an angle of incidence of 35 degrees. The speed of the refracted wave is observed to be 96 m/s.
I need to find the speed of waves from the second source in the originial medium and if the angle of refraction of the waves from the second source are greater, less or equal to 35 degrees as they enter the different medium.
2. Relevant equations
The universal wave equation is V = (f)(L)
V = speed
f = frequency
L = wavelength
also f = 1/T
T = period (time) f anf t are reciprocals of each other
3. The attempt at a solution
Given: f = 75Hz
refracted v = 96m/s
angle of incidence = 35 degrees
Required: speed (v)
wavelength (L)
Analysis: V = (f)(L)
= (75)(?)
I just don't know how to find either the v or the L as this is the only formula I've been given and I can't use it with two variables. I tried making a graph with the angles but didn't have enough information. I don't know if I can somehow use the angles to calculate the refracted wave's original speed or if there's a way to use the refracted wave's speed to calculate the original speed. This is a grade eleven physics problem and I am so frustrated with this and can't see a way to solve it. If someone could even just help me find the wavelength of the second source that would help a lot.
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Dec15-10, 01:31 PM   #2
Can anybody help with this?
New Reply
Similar discussions for: Help with Transverse Wave Equation
Thread Forum Replies
The 4-D Laplace equation and wave equation Special & General Relativity 1
I must use the wave equation to to find the speed of a wave. Introductory Physics Homework 3
Wave on a rope - question concerns the maths of the wave equation Introductory Physics Homework 3
wave equation, transverse wave Introductory Physics Homework 3
wave equation and graphing wave instance Advanced Physics Homework 0
