Why Does Ohm's Law Calculation for External Resistor R Seem Incorrect?
  • Thread starter Thread starter vsage
    Law Ohm's law
The discussion centers on calculating the value of an external resistor R connected to a 12.0 V battery with an internal resistance r. The terminal voltage measured is 11.7 V with a current of 0.10 Amperes flowing through the circuit. The correct calculation involves recognizing that the total resistance Rt is the sum of the internal resistance r and the external resistor R. The final calculation reveals that R equals 118.8 ohms when the internal resistance r is determined to be 1.2 ohms.
  • Understanding of Ohm's Law and its application in circuits
  • Knowledge of electromotive force (emf) and terminal voltage concepts
  • Familiarity with series and parallel resistor configurations
  • Basic algebra for solving equations involving resistances and currents
  • Study the principles of internal resistance in batteries
  • Learn how to analyze circuits with both series and parallel resistors
  • Explore the concept of terminal voltage in practical applications
  • Investigate the effects of varying load conditions on battery performance
Electrical engineering students, hobbyists working with circuits, and anyone interested in understanding battery behavior and resistor calculations.
vsage
A 12.0 V battery has an internal resistance r. The measured voltage (emf of the battery) is 12.0 V. When connected to a resistor R the terminal voltage is 11.7 V and the current is 0.10 Amperes. What is the value of the external resistor R in ohm?
Ok I thought the problem was simple but for some reason I keep getting it wrong. (E denotes electromotive force). I set up conservation of energy like this:
E - V(resistor) = 11.7
E = 12 in this case and V = i*R = 0.1*R
so..
12 - 0.1*R = 11.7
R equals 3 from my equation but it's wrong. Dead wrong. Any ideas? It's the language that seems most unclear to me.
Try this:
[tex]I_{T}=\frac{V_{applied}}{R_{T}}[/tex]
and remember what the total resistance is in this case.
Maybe my problem is more how the question is worded.. here is what I interpreted from what you said. A simple yea or nay will either send me back to the books or confirm I understood something:
It = Vapplied/Rt
since the resistors (r and R) are in parallel, Rt = R + r. Current is constant in the system so It = 0.1a but I'm a little confused as to what Vapplied is. Is that the emf? So I'm left with
0.1 = 12V / (r + R) but now I have two unknowns. ugh. Undoubtedly little r was given to me in the question but I'm having trouble wading through the semantics. I see that I haven't used that 11.7 yet.
Edit wait: emf = 0.1 * r right? So r must be 1.2..
0.1 = 12V / (1.2 + R)
R = 118.8? Edit again: Got it right. Thanks I can be so nearsighted sometimes. That was discussed in the lecture I came from not two days ago!
13K
