New Reply
3 Optic Problems
Share Thread Thread Tools
Dec15-10, 10:43 AM   #1
3 Optic Problems
I have 3 questions to solve in 2 days for my coursework.. All the questions are about optical physic, thx for the answers..
PROBLEM 1
Refracting prism with the angle O=60° between the refracting surfaces is made of glass with a refractive index n . If the angle of incidence at the first surface of prism is ? the angle of deflection d=42 is minimum ( d=dmin)
Find the glass refractive index n and angle of incidence ?
2. Relevant equations
n1.sin1=n2.sin2
3. The attempt at a solution
I tried to draw the prism but I couldn't
PROBLEM 2
Light ray entering normally to the first surface AB of prism is reflected successively at the surfaces AC and BC and refracted at surface AC. Calculate the angles of prism ( a,ß, x ) if the angle of incidence of outgoing ray at the surface AC is zero and the angle between the incoming and outgoing ray is d=44°
n1.sin1=np.sin2
a+ß + x = 180°
I know i have to use angles but I couldnt draw the prism
PROBLEM 3
An optical system is composed of two positive thin lenses in air medium at distance d between them. The lenses are made of glass with refractive index n and the radii of curvature for the first lens surfaces are R'1 and R'2 and for the second lens surfaces are R''1 and R''2
a) Find the optical power F1 and F2 and focal length f1' and f2' of each lenses.
b) Calculate the position and size of the image of the object of size Y placed at a distance a1 in front of a first lens
c) Construct the image of the object from 1b) graphically
d) Calculate the new position and size of the image of the object from 1b if the plane parallel plate of thickness t is introduced between the lenses
TABLE 1B
n = 1.7
R'1 = 36.40
R'2 = -36.40
R''1 = 67.20
R''2 = -67.20
d = 48
a1 = -31
Y1 = 10
t = 12
I tried Bessel's Method to solve this problem but I couldn't, actually I dont know much about this task
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Dec15-10, 12:01 PM   #2
anybody to help ? at least tell me how to start, because really I dont know much about optic
Dec15-10, 12:07 PM   #3
plug in what you know and then isolate for the missing variable. Doing this will allow you to get the correct answer for question number one.
Dec15-10, 12:17 PM   #4
3 Optic Problems
Quote by barthayn View Post
Thx for the answer but I cant remember anything about optic, those formulas I have written are from internet and old books, I cant find anymore information about this subject
Dec15-10, 02:31 PM   #5
Admin
But you know what refraction and reflection is?
For second problem - simply draw a triangle ABC, that's your prism.
Light enters normally - that means it is perpendicular to the surface, so there is no refraction. Draw a line perpendicular to AB. It crosses AC - that's the point where it reflects. Draw reflected ray (easy - angle of incidence equals the angle of reflection). Reflected ray hits BC and reflects - repeat the same procedure. Finally reflected ray gets to AC and exits prism changing direction because of refraction.
New Reply
Thread Tools
Similar Threads for: 3 Optic Problems
Thread Forum Replies
Optic Introductory Physics Homework 1
Optic help Introductory Physics Homework 13
need help on an optic question Introductory Physics Homework 2
optic Classical Physics 2
