New Reply
simple statics problem
Share Thread Thread Tools
Dec15-10, 12:48 PM   #1
Guys
I need some help with a simple statics problem.
I have a bar with a length of Z from point A to point B. A torque is input at point c which is located a length of Y from point A. There are two reaction forces: Fb located at Point B and Fa located at point A. no other forces are input. I am having problems doing my sum of forces and moments.
I know for zero rotation the sum of moments is at point c
T=Fb(Z-Y) + Fa(Y)
However, I can't seem to find the correct sum of forces in one direction let's just say x.
With the sum of forces I get FB = FA I know this isnt true because they are two different distances from Point C and there will have different magnatudes. any help would be appreciated.
I am thinking I need to some how convert T to a force with some sort of ratios of the lengths. any assistance would be appreciated.
I can't believe this simple of a problem is kicking my butt.
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Dec15-10, 03:38 PM   #2
Try doing the sum of the moments about each end (A and B). About point A, there is no moment due to Fa and then you only have the moment around C and then the moment caused by Fb a distance of Z units away. You solve for Fb. Repeat the process for Fa, but take the moment about point B.
Hope this helps.
New Reply
Thread Tools
Similar Threads for: simple statics problem
Thread Forum Replies
Statics Problem, Simple 2d rectangle with forces acting on it. Engineering, Comp Sci, & Technology Homework 9
Statics: bad solution to simple truss problem regarding determinancy Introductory Physics Homework 5
Seemingly Simple Statics Problem Introductory Physics Homework 9
Simple statics Introductory Physics Homework 4
Seesaw: simple statics problem????? Introductory Physics Homework 2
