Compressed air cylinder temperature during rapid depressurisation
The discussion revolves around the temperature changes of compressed air cylinders during rapid depressurization and the implications for the integrity of the pressure vessel. Participants explore the heat transfer dynamics between the compressed air and the cylinder wall, particularly under varying pressures and temperatures, and consider the potential risks of embrittlement due to repeated blowdowns.
  • One participant seeks to understand the temperature drop of air cylinders during rapid expansion and its effect on the cylinder material, particularly regarding the ductile to brittle transition temperature.
  • Another participant notes the importance of specifying the amount of compression and highlights that the convection coefficient changes with the density of the air during expansion.
  • A participant mentions the need to model the system to account for varying starting and end pressures, emphasizing that ideal gas assumptions may not hold at high pressures like 300 bar.
  • Concerns are raised about the risk of embrittlement of the cylinder surface due to repeated blowdowns and the associated fatigue stress on the pressure vessel.
  • Discussion includes the heat transfer coefficient between the compressed gas and the cylinder wall, with some proposing an overall thermal resistance model involving external and internal convection coefficients.
  • One participant expresses a desire to calculate the R-value for an air film at specific pressures and temperatures, indicating a need for a more detailed mathematical approach.
  • Another participant reflects on the intuitive notion that higher pressure gases might have higher heat transfer coefficients due to closer molecular proximity, referencing a heat transfer coefficient table for context.
Participants express various viewpoints on the heat transfer dynamics and the implications of pressure changes, with no consensus reached on the exact relationships or calculations involved. The discussion remains unresolved regarding the specific calculations for thermal resistance and the risks of embrittlement.
Limitations include the dependence on specific assumptions about gas behavior at high pressures, the need for detailed mathematical modeling of thermal resistance, and the variability of convection coefficients with changing conditions.
Airou
Hi guys,
Here's an interesting problem for you. I'm trying to understand what happens to the temperature of air cylinders as the compressed air within is rapidly expanded to see if the surface in contact with the expanding air gets so cold it passes through the ductile to brittle transition temperature.
I can use Refprop and iteration to work out the temperatures and pressures adiabatically, but what I am struggling with is figuring out the heat flow into the rapidly cooling air from the surroundings through the wall of the cylinder.
For the external skin of the cylinder (in contact with ambient, room temperature air) I have assumed an air-to-surface thermal resistance of 0.123 m^2K/W used as a rule of thumb in the construction industy for internal wall surfaces in calculating heat losses in buildings, but I have no idea what the surface-to-air resistance would be from the steel to compressed air and how that figure changes with pressure and temperature.
Any thoughts/pointers to where I can find that info would be greatly appreciated.
you have not mentioned the amount of compression. also the convection coefficient varies as the density of the air within the cylinder changes during expansion.
Thanks for the reply. I'm trying to make a model of the system that allows me to vary the starting pressure in the cylinder and deplete it to various end pressures as I vary the time period over which the depressurisation occurs. Typically though I will be at the 300 bar level where ideal gases can't be assumed.
Yes, it is how the convection coefficient changes with time as the thermodynamic properties of the air changes as it goes from 300 bar at ambient pressure to 40 bar at circa -100C in about 15 seconds that I am looking for. All my books, googling etc. only really look at what occurs at ambient conditions and with ideal gases.
I'm trying to ascertain if repeated blowdown of cylinders present a risk to the integrity of the pressure vessel by embrittling the surface in contact with the expanding air.
Many thanks :)
what i got from ur question is that what will be the heat transfer coefficient between the compressed gas and the cylinder wall.
We can use another approach. let's say the convection coefficient between outside air and cylinder wall is X :-P
now the air inside the cylinder is expanding to 40 bar which is greater than outside pressure, hence the density of the air inside the cylinder would also be greater making this clear that the inside heat transfer coefficient would be less as compared to the outside. so u can assume the overall thermal resistance as : X + Y + X
where Y is the thermal resistance of cylinder wall.
of course repeated compression and expansion exerts a fatigue stress in the pressure vessel. within elastic limit, the vessel would face as many stress changes as there are strokes of compression expansion
Yes, I want to understand how the heat transfer coefficient changes as the temperature and pressure of the air in the cylinder falls.
Intuitively I would have thought that a higher pressure gas has a higher heat transfer coefficient as the molecules would be closer together enabling more rapid heat transfer as the mean path between collisions would be less.
My guesses seem to be reflected in this table:
http://www.engineeringtoolbox.com/heat-transfer-coefficients-exchangers-d_450.html
I appreciate the answer, but I'm not really looking for a quick fix. I'd really like to know how to calculate the R-value for an air film for a given pressure and temperature.
well, what you want is not impossible, but you would need to involve some mathematics in your solution :-P
i could've worked with a general solution about the variation in the thermal resistance with temperature and pressure of an ideal gas but I'm stucked in a job deeply . .
Regards
  • · Replies 45 ·
  • · Replies 16 ·
  • · Replies 26 ·
