Is the Image of a Homomorphism f(G) Always a Subgroup of H?
  • Thread starter Thread starter steroidjunkie
The discussion revolves around the properties of the image of a homomorphism from one group to another, specifically whether the image of a homomorphism f from group G into group H is always a subgroup of H.
  • Participants express uncertainty about how to begin the problem and seek hints. Some suggest starting with definitions and consider the properties of homomorphisms, such as their effects on identities and inverses. Others mention the need to demonstrate that the image set is nonempty and satisfies subgroup criteria.
There is an ongoing exploration of the problem, with participants providing guidance and prompting further questions. Some have articulated specific properties that need to be shown for the image to qualify as a subgroup, while others are still in the process of formulating their thoughts.
Participants are encouraged to clarify their equations and reasoning, indicating a focus on precise mathematical communication. The discussion reflects a collaborative effort to unpack the definitions and implications of homomorphisms in group theory.
steroidjunkie
1. Show that image of homomorphism f of group G into group H is a subgroup of H.
2. f(G) [tex]\equiv[/tex] { f(g) | g [tex]\in[/tex] G } [tex]\subset[/tex] H
The problem is I don't know how to start. So if I could get a hint it would be great...
You need to show f(G) is nonempty and if h1 and h2 are in f(G), then h1*h2-1 is in f(G), where * is the group operation in H.
Definitions are usually a good place to start. Most "simple" problems like this are trivial exercises in naive set theory after the translation.
Thank you for your guidelines. This is what I came up with: (click on the picture to show it and again to see it clearly)
It will be much easier to have a discussion if you put your equations here. Use the X2 button for superscripts. So it is easy to write a-1.
You might start by answering this: What is the test for a subset M of a group G to be a subgroup?
What do homomorphisms do to the identity and to inverses?
I think i found the solution. I need to show that f(G) is a nonempty set and that for every g1 and g2 element f(G): g1*g2-1 element f(G) by prooving four axioms of group.
And the answer to the second question is: homomorphism of an identity is an identity and homomorphism of an inverse is an inverse.
Thank you to both of you.
