What is the solution to cos[arcsin (-4/5) + arccos (12/13)]?
  • Thread starter Thread starter dkotschessaa
    Function Trig
The discussion focuses on evaluating the trigonometric expression cos[arcsin(-4/5) + arccos(12/13)]. The solution involves applying the cosine sum identity: cos(A + B) = cosAcosB - sinAsinB, where A = arcsin(-4/5) and B = arccos(12/13). The correct answer is determined to be 56/65, achieved by calculating the necessary sine and cosine values from the respective right triangles. The participants emphasize the importance of understanding the geometric representation of the angles involved.
  • Understanding of trigonometric functions and their inverses, specifically arcsin and arccos.
  • Knowledge of the cosine sum identity in trigonometry.
  • Ability to apply the Pythagorean theorem to find missing sides in right triangles.
  • Familiarity with sketching right triangles based on given side lengths.
  • Study the cosine sum identity in detail, including examples and applications.
  • Learn how to derive sine and cosine values from right triangles using the Pythagorean theorem.
  • Explore additional trigonometric identities that involve the addition of angles.
  • Practice evaluating more complex trigonometric expressions involving inverse functions.
Students studying trigonometry, educators teaching trigonometric identities, and anyone seeking to improve their skills in evaluating trigonometric expressions involving inverse functions.
dkotschessaa
Evaluate the trigonometric expression (several examples). Hint: In each case, sketch a right triangle. For example, in the first case, sketch a right triangle with a hypotenuse of length 5 and one leg of length 3. Let A be the angle opposite the side of length 3. Solve for the length of the third side, and then look at the sketch to find tanA.
First example (which I solved) tan(arcsin 3/5)
Second Example (I'm boggled :confused:) cos[arcsin (-4/5) + arccos (12/13)]
For the first example tan(arcsin 3/5)
The missing side of the triangle by the Pythagorean theorem turns out to be 4 ,so tanA= opposite (3) over adjacent (4) = 3/4. No problem.
For the second...
Since I've been specifically asked to draw a right triangle, I go along with it - I draw one with a side of -4 and solve the missing side for 3. The second triangle I get a missing side of 5.
Of course I can use a calculator and calculate the angles, add them together and take the cosine, but that's not what's being asked. I've tried various means of seeing if we're talking about one triangle instead of two, by drawing one a hypotenuse of length 65 (multiplying the hypotenuse of each). The other two sides are 60 and -40. This doesn't help. I know the answer is 56/65 I don't know how to get to it.
I've even tried putting the hypotenuse of triangle A as the opposite side of triangle B but I just get some bizarre shape that doesn't tell me anything. I don't know any trig identities that involve adding a sin of one angle with the cosine of another, much less their inverses.
I'm basically not understanding conceptually what's being asked here. Even if I wasn't dealing with this -4 in the equation I wouldn't know how to add these two.
-DaveKA
For the second...
-DaveKA
Start by using the sum of angles identity for cosine: cos(A + B) = cosAcosB - sinAsinB, where A = arcsin(-4/5) and B = arccos(12/13). From there, you should be able to use right triangle trig to find the two remaining values.
Perfect, Mark. Thank you!
  • · Replies 59 ·
232K
