How Does Time and Space Switch Roles at a Black Hole's Event Horizon?
The discussion centers on the geometric interpretation of time and space switching roles at the event horizon of a nonrotating black hole, particularly in the context of the Schwarzschild metric. Participants explore the implications of this role reversal for objects falling into a black hole and the nature of spacetime inside and outside the event horizon.
  • One participant inquires about the geometric meaning of time and space switching roles at the event horizon and whether objects inside the event horizon remain in the same 4-dimensional spacetime as observers outside.
  • Another participant suggests that outside the event horizon, movement is restricted to forward in time, while inside, movement is restricted to smaller radial distances, raising questions about the nature of spacetime connectivity.
  • A later reply asserts that the Schwarzschild metric consists of 4 spacetime dimensions both inside and outside the event horizon.
  • Some participants argue that the spacetime inside the event horizon is causally disconnected from that outside, leading to uncertainty about whether they constitute the same spacetime.
  • One participant emphasizes that the perceived switching of time and space is a coordinate effect rather than a physical change, noting that an observer falling through the event horizon would not notice this switch.
  • Another participant reiterates that spacetime behaves locally the same everywhere, questioning the understanding of the 'switching' as merely a coordinate chart effect.
Participants express differing views on whether time and space actually switch roles or if this is merely a coordinate effect. There is no consensus on the implications of this switching for the nature of spacetime inside and outside the event horizon.
Participants note the limitations of their discussion, particularly regarding the interpretation of coordinate effects versus physical reality and the implications of causal disconnection between regions of spacetime.
scope
hello,
what does exactly mean geometrically that time and space switch roles at the event horizon of a nonrotating black hole?. I understand that the - for time becomes a + and the + for space becomes -, but how to interpret it geometrically?
also I want to know if after the event horizon, inside the black hole, (its nearly the same question) whether the infalling object is still in exactly the same 4-dimensionnal spacetime as the observer or if the object has exited it.
thank you!
One way to look at it is that outside the event horizon you can only move forward in time, not backward. Similarly inside the event horizon you can only move to smaller r, you can't move to larger r no matter what you do. Your second question is more philosophical. The spacetime inside the event horizon is causally disconnected from the spacetime outside the event horizon, so what is inside the event horizon cannot influence what is outside. Does this mean it is not "the same spacetime"? I'm not sure.
thanks, but for the second question i was just wondering if the content of the black hole inside the event horizon is exactly contained in the same 4 spacetime dimensions of the observer. I mean: are only 4 spacetime dimensions required to contain the behavior outside of the event horizon and inside of the even horizon(without talking about the singularity) for a Schwarzschild black hole, mathematically (Schwarzschild metric)?
thanks
Yes, a Schwarzschild metric has just 4 spacetime dimensions, both inside and outside the event horizon.
What's inside the horizon can't causally influence what's outside, but what's outside *can* influence what's inside. So the region inside the horizon is still part of the same spacetime. The reason causal influences can't propagate from inside the horizon to outside is simply that to do so, they would have to travel faster than light, and causal influences can't travel faster than light.
Time and space do not switch roles at the EH.
I think you are confused by the behavior of Schwarzschild coordinates outside and beyond the event horizon where the r looks like t and the t like r. But this is a coordinate effect not something physical.
And observer free falling through the EH will not notice anything related to switching space and time.
of course i was referring about the coordinate effect: how the spacetime inside the event horizon behaves mathematically in the observer reference frame. in such case, time and space switch roles
Spacetime behaves locally the same everywhere. I am still not convinced if you fully understand that this 'switching' is simply a coordinate chart effect and nothing physically.
  • · Replies 51 ·
  • · Replies 46 ·
10K
  • · Replies 73 ·
  • · Replies 20 ·
  • · Replies 22 ·
  • · Replies 25 ·
