Banked Race Track Physics Problem: Max and Min Speeds without Friction
The banked race track physics problem involves calculating the minimum and maximum speeds for cars on a track with inner radius r1 = 111 m and outer radius r2 = 163 m, with an outer wall height of 18 m. The smallest speed without friction is determined to be 0 m/s, occurring when the track is flat (θ = 0). The largest speed is theoretically infinite, as it corresponds to the steepest angle (θ = 90 degrees), indicating no upper limit in a frictionless scenario. However, practical conditions will always introduce friction, limiting actual speeds.
  • Understanding of basic physics concepts, specifically circular motion.
  • Familiarity with trigonometric functions, particularly tangent.
  • Knowledge of gravitational acceleration (g = 9.81 m/s²).
  • Ability to manipulate and solve equations involving square roots and angles.
  • Study the derivation and application of the centripetal force equation in circular motion.
  • Learn about the effects of friction on banked curves in vehicle dynamics.
  • Explore real-world applications of banked tracks in motorsport engineering.
  • Investigate the role of gravitational forces in inclined planes and their impact on motion.
This discussion is beneficial for physics students, automotive engineers, and anyone interested in the dynamics of vehicles on banked tracks, particularly in frictionless scenarios.
shawonna23
On a banked race track, the smallest circular path on which cars can move has a radius r1 = 111 m, while the largest has a radius r2 = 163 m. The height of the outer wall is 18 m.
(a) Find the smallest speed at which cars can move on this track without relying on friction.
(b) Find the largest speed at which cars can move on this track without relying on friction.
I think that I'm supposed to use this equation:
v= Square root of (r)(g)tan theta, but I don't know how to find theta?
you can make a triangle out of the info given. Assuming the base of the track is on the x-z plane, you can create a triangle by taking a cross section pointing radially inward from the circle pointing in the positive y direction. Anyway that's not relevant just trying to give you a reference point. The two legs of the triangle would be (163-111) on the bottom and 18 going up. From this you can find an incline (theta) and you're solving for V.
Yes, you are correct that the equation v = √(r*g*tanθ) can be used to solve this problem. To find θ, we can use the fact that the height of the outer wall (18 m) is equal to the difference in height between the two circular paths (r2 - r1). So, we can set up the following equation:
tanθ = (r2 - r1)/18
(a) To find the smallest speed, we want to find the minimum value of θ. This occurs when the track is completely flat (θ = 0). So, we can plug in θ = 0 into the equation and solve for v:
v = √(r1*g*tan0) = √(r1*g*0) = 0
Therefore, the smallest speed at which cars can move on this track without relying on friction is 0 m/s.
(b) To find the largest speed, we want to find the maximum value of θ. This occurs when the track is at its steepest angle. So, we can plug in the maximum value of θ (90 degrees or π/2 radians) into the equation and solve for v:
v = √(r2*g*tan(π/2)) = √(r2*g*∞) = ∞
Therefore, the largest speed at which cars can move on this track without relying on friction is infinity. This means that there is no limit to the speed of the cars on this track as long as there is no friction. However, in reality, there will always be some amount of friction present, so the actual maximum speed will be less than infinity.
