What is the Solution to the Equation 2x = x^2?
  • Thread starter Thread starter I Like Pi
    Hard
The discussion revolves around solving the equation 2x = x^2, which falls under algebraic equations. Participants explore various methods to approach the problem without arriving at a definitive solution.
  • Some participants attempt to solve the equation algebraically, while others suggest using logarithms or fractional exponents. There are questions regarding the validity of certain algebraic manipulations and the potential for multiple solutions.
The discussion is active, with participants sharing different perspectives on the solvability of the equation. Some guidance has been offered regarding the use of logarithms, though there is no consensus on a straightforward method to solve it analytically.
Participants note that the equation may have multiple solutions, and there are references to advanced mathematical concepts like the Lambert W Function, which may not be familiar to all participants. There is also mention of the expectation from the teacher or textbook regarding the solution.
I Like Pi
solve 2x = x2
i have no clue
x = 2
tommowg said:
x = 2
how do you solve it algebraically tho
Try using logs.
p21bass said:
Try using logs.
i get xlogx = 2log2
No - that's wrong. You seem to have divided where you should have multiplied.
tommowg said:
x = 2
But that is not the only answer.
I'm not sure you can solve this with simple algebra though. Using fractional exponents or logs may make it easier to look at with x's on one side, but not necessary solvable.
I agree with Apphysicist. There is no simple way to solve for x analytically in this equation.
There are 3 solutions in the set of real numbers:
x = 2 is surely a solution;
The other two are in the intervals:
x > e and
-1 < x < 0
Your teacher / book probably just wants you to give 2 as an answer. Other answers would be in terms of something like the Lambert W Function, which is something you wouldn't even know exists until you've had a few more years of math.
m.wolframalpha.com/input/?i=%32^x%20%3d%20x%c2%b2&x=0&y=0
x = 2
x = 4
Another approximate solution is:
[tex] x \approx -0.7666646959621232[/tex]
  • · Replies 24 ·
