Understanding ADSL DMT Carrier Waves: Questions & Answers
  • Thread starter Thread starter bradland
    Carrier Waves
The discussion focuses on understanding ADSL (Asymmetric Digital Subscriber Line) DMT (Discrete Multitone) carrier waves, exploring the nature of the carrier wave, the electrical characteristics of ADSL connections, and the implications of power spectrum density (PSD) in this context. Participants raise questions about the physical components involved, the functioning of ADSL systems, and the relationship between AC and DC signals.
  • One participant questions whether the ADSL carrier wave is made of photons or electrons, suggesting that it is an electronic system.
  • Another participant explains that the two wires in an ADSL connection are necessary for AC transmission, even if they appear as open wires in a dry loop test.
  • There is a discussion about the nature of the ADSL signal being primarily AC and the types of modulation used, including QAM (Quadrature Amplitude Modulation) and its variants.
  • Participants discuss the concept of Power Spectrum Density (PSD), describing it as a metric for stochastic signals that can indicate errors and channel capacity. They note that PSD can be used for error detection and correction in ADSL systems.
  • One participant elaborates on the complexities of defining DC in practical terms, suggesting that what is considered "DC" can vary based on frequency and context.
  • Several resources and references are provided for further reading on ADSL and related topics.
Participants express varying levels of understanding and interpretation of the concepts discussed, with no clear consensus on all points. Some technical aspects are clarified, but multiple views on the nature of signals and definitions remain present.
Participants acknowledge that the discussion involves complex technical details, and some concepts may be challenging to grasp without a background in engineering or related fields. The relationship between AC and DC in the context of ADSL is particularly nuanced and not fully resolved.
This discussion may be useful for individuals interested in telecommunications, signal processing, and the technical workings of ADSL technology, particularly those seeking to deepen their understanding of carrier waves and modulation techniques.
bradland
Hello,
I am hoping someone out there can me better understand how an ADSL DMT carrier wave works. Is the carrier wave made of photons or electrons?
I have tested the dry loop at my house and from what i can tell this is not an electrical circuit, but two open wires. This begs the question why are two wires needed?
If the signal is composed of electrons what direction(s) does the current flow through the wires? How does this relate to a DC or AC current.
How does the ADSL line driver generate the carrier signal?
What does the Power spectrum density measure in layman terms ?
How does the PSD relate to an AC or DC voltage?
I understand it may be difficult to explain in one post but any reference to books or websites would be greatly appreciated. thanks, brad
bradland said:
Hello,
Electrons. It's an electronic system, not a photonic system. You may have an upstream connection beyond the ADSL modem on the phone company side (called a DSLAM) that is fiber optic but you can completely separate the ADSL portion from it both conceptually and in terms of testing.
It simply means the wires are connected to a high impedance. If you have an ADSL filter installed, this is what you'd expect for a DC measurement because the filter is isolating the voice channel of the POTS from the ADSL channel, which is at frequencies above the voice channel. Only the voice channel goes down to DC (it uses DC for on-hook/off-hook signaling and for power).
You still need 2 wires for a transmission line for AC, which ADSL is.
bradland said:
If the signal is composed of electrons what direction(s) does the current flow through the wires? How does this relate to a DC or AC current. How does the ADSL line driver generate the carrier signal?
ADSL is primarily a modem signal that is purely AC. All modulated signals are AC. ADSL just happens to be a digital modulation that is outside the standard voice channel spectrum of POTS. Analog modulation includes stuff like AM, FM and PM. Digital modulation includes FSK, PSK, QAM, etc. ADSL uses QAM (quadrature amplitude modulation) in several variants. CAP is the simplest and uses straight QAM. DMT uses several varieties of QAM at once.
bradland said:
What does the Power spectrum density measure in layman terms ? How does the PSD relate to an AC or DC voltage?
The actual ADSL signal is "stochastic" or "randomly changing in a predictable statistical way" because the actual data going over the wire depends on what's transmitted and really can't be known before hand. And to unnecessarily confuse the issue, there are reasons having to do with maximizing channel capacity why you want the resultant modulation to be "extra random" in a predictable way.
Power Spectrum Density is a metric for stochastic signals that can be used for error detection and correction. It's basically looking at a signal with a spectrum analyzer but with long-term statistics about the power at each frequency. Most spectrum analyzers can extract a PSD approximation for you. When you have a PSD that doesn't match the channel frequency characteristics it generally means you are getting errors and/or lower effective transfer bandwidth. See the PDF link below for what the frequency characteristic of ADSL is suppose to look like.
You can also use the PSD to perform certain types of corrections for channel distortion and signal impairment. An ADSL modem will use an approximation of PSD to do this automatically using digital signal processing (DSP).
DC only in the sense of "What frequency DC?" There is mathematically ideal DC and then there is "DC" that engineers (and electronics hobbyists) use. Often folks think "DC" is ideal DC but it's not.
In a strict mathematical sense, "DC" is a very fuzzy concept because at some point you had to turn on the "DC" and that act introduces a low frequency AC component to the "DC". Thus "DC" is actually ideal DC and AC mixed together.
So EEs who do DSP and microwave work will often talk about "What frequency DC do you really mean?" because what constitutes "DC" is frequency dependent quantity in practice. Many microwave engineers consider 30 MHz to be "DC", for instance.
A signal's PSD can have a DC component with all the AC components. However because ADSL operates in a band above voice audio and this ideal DC (or most intuitive senses of DC frequency), DC doesn't matter with ADSL's PSD. For ADSL, "DC" is any frequency below the top of the POTS voice channel.
See also:
http://en.wikipedia.org/wiki/Spectral_density
These PDF document will probably help:
http://home.pacbell.net/bitrider/tb1000.pdf
http://www.sce.carleton.ca/courses/sysc-5403/f06/DSL_ST.pdf
The math on the 2nd one is both essential to really understanding ADSL in detail but also very hairy if you don't have an engineering degree.
Also you can go look at the various ITU standards for modems that operate in the POTS voice channel because the more recent ones (e.g. V.32bis) are pretty similar to ADSL modulation except that ADSL operates above the voice channel to much higher bandwidth (hence the higher speed possible compared to voice channel modems).
http://www.itu.int/itu-t/recommendations/index.aspx?ser=V
Very nice post, jsgruszynski! :smile:
Thanks jsgruszynski. That is an awesome post.
