How Fast Should a Motorcyclist Go to Stay on a Loop?
  • Thread starter Thread starter ptrainerjoe
    Loop
A stunt motorcyclist must travel at a minimum speed of 11 m/s to avoid leaving the surface at the top of a vertical circular ramp with a radius of 8 m. The discussion highlights a common misunderstanding regarding uniform speed and the role of nonconservative forces, particularly in the context of freshman-level physics problems. The formula used to determine the required speed is v = sqrt{RG}, where R is the radius and G is the acceleration due to gravity. The discrepancy between the calculated speed of 8.9 m/s and the book's answer of 11 m/s is attributed to the need for additional considerations regarding forces acting on the motorcyclist.
  • Understanding of circular motion and centripetal force
  • Familiarity with the concepts of kinetic energy and work-energy principle
  • Knowledge of nonconservative forces and their effects on motion
  • Basic proficiency in algebra and physics problem-solving
  • Study the concept of centripetal acceleration in circular motion
  • Learn about the work-energy theorem and its applications
  • Explore the effects of friction on motion in circular paths
  • Review examples of similar physics problems involving forces and energy
Students in introductory physics courses, particularly those studying mechanics, as well as educators looking for examples of problem-solving in circular motion scenarios.
ptrainerjoe
Heres the problem:
A stunt motorcyclist rides with uniform speed on the inside rim of a vertical circular ramp of radius 8 m. How fast must the motor cyclist travel to aviod leaving the surface at the top of the loop.
the answer in the back of the book says 11m/s but I keep getting 8.9m/s. After working out the formula isn't the final formula v=sqrt{RG}?
Thanks ahead of time for the help!
What do you mean by "A stunt motorcyclist rides with uniform speed". If the cyclist is traveling at UNIFORM speed as he travels up the ramp, there is a nonconservative force acting on the cyclist and ENERGY IS NOT CONSERVED. Does the problem give you any information about the coefficient of static friction? If so, you can use the following:
[tex]W_{nc} = \mu_{s}\int_{0}^{<br /> \pi/2} N(\theta) R d\theta = E_{f} - E_{i} = \frac{1}{2}mv_{f}^2 + mg(2R) - \frac{1}{2}mv_{i}^2[/tex]
where [tex]W_{nc}, N(\theta)[/tex] is the work done by the nonconservative force and the normal force as a function of angle, respectively. The subscripts [tex]i, f[/tex] denote final and inital points. I took the initial point to be when the cyclist enters the ramp and the final point to be where the cyclist is at the top of the loop. You can simplify the above equation because [tex]v_{f} = v_{i}[/tex]
However, read the question again carefully. You may have confused the wording. It sounds like this is a typical freshman level physics problem and usually they aren't this complicated.
yes it is a freshman level physics 1 course. We have gone through forces and are just starting work and kinetic energy. The problem is written down exactly as it is in the book. I had a hard time with the way it was written as well that's why i needed the help.
Heres an example of how someone else worked it out. I did it the sameway.
http://physics.mercer.edu/balduz/GenPhys/phy161images/B/b19.pdf
I think my answer is right but the answer in the back of the book says otherwise. I just want to make sure that it is right before i turn it in today at 1pm
  • · Replies 19 ·
  • · Replies 21 ·
