Tension on the table top pulley
The discussion centers on calculating the work done by the tension in a rope during the lifting of a 37kg load using a frictionless pulley. The load moves a distance of 7.5m at a constant velocity, resulting in a tension of 362.6N, which is equal to the weight of the load (37kg multiplied by 9.8m/s²). The work done by the tension is calculated using the formula W = Fd, yielding a total of 2719.5J. It is clarified that while the rope is in motion, the tension itself does not perform work; rather, the work is done by the person pulling the rope.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of force, weight, and tension
  • Knowledge of work-energy principles
  • Basic proficiency in using formulas for calculating work (W = Fd)
  • Study the principles of static and dynamic equilibrium in physics
  • Learn about the mechanics of pulleys and their applications
  • Explore the concept of work done by various forces in different scenarios
  • Investigate the role of friction in pulley systems and how it affects tension
Students of physics, engineers, and anyone interested in understanding the mechanics of pulleys and the calculations involved in work and tension in lifting systems.
ptrainerjoe
heres the problem:
A person pulls a heavy load of mass 37kg up the side of a building by using a frictionless pulley. The load travels up a distance of 7.5m. Take the load to move with ocnstant velocity and ignore any acceleration at the beginning or end of the move. How much work is done by the tension in the rope?
I know the work done by the person and gravity(which are the other two parts of the question) but I'm getting stuck on this part. I'm thinking it would be zero but the rope is moving so i don't know
Thanks for the help.
Work equals force times distance. That's all you need.
Since there was no acceleration, the force in the rope is exactly equal to the weight of the load.
The tension on the table top pulley is an important factor to consider in this problem. In order for the load to move with a constant velocity, the tension in the rope must be equal to the weight of the load. This is because the upward force of the tension must balance out the downward force of gravity acting on the load.
In this scenario, the tension in the rope would be equal to the weight of the load, which is 37kg multiplied by the acceleration due to gravity (9.8m/s^2), giving us a tension of 362.6N. This tension remains constant throughout the 7.5m distance that the load is pulled.
Now, to calculate the work done by the tension in the rope, we can use the formula W = Fd, where W is work, F is force, and d is distance. In this case, the work done by the tension would be 362.6N multiplied by 7.5m, giving us a total work of 2719.5J.
It is important to note that while the rope is moving, the tension is not actually doing any work on the load. The work is being done by the person pulling the rope, using their own energy and exerting a force on the rope. The tension in the rope is simply a means of transferring this force to the load.
In conclusion, the work done by the tension in the rope in this scenario is 2719.5J. I hope this helps clarify any confusion you may have had. Keep up the good work!
  • · Replies 38 ·
  • · Replies 22 ·
  • · Replies 33 ·
