Maximum height of projectile motion
The discussion revolves around a projectile motion problem involving the calculation of maximum height given an angle of projection and horizontal displacement. The original poster is attempting to solve for the maximum height of a projectile launched at a 25-degree angle with a final horizontal displacement of 301.5 meters, while considering gravitational acceleration.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss rearranging standard projectile motion formulas to find time and initial velocity. There are suggestions to equate time derived from horizontal and vertical displacement equations. Some participants also mention using the range equation to derive initial velocity.
The discussion includes attempts to identify mistakes in calculations, with one participant expressing confusion over their results compared to the book's answer. There is acknowledgment of correct calculations by another participant, but no consensus on the resolution of the discrepancy.
Participants are working under the constraints of the problem as presented in the book, which lacks sample problems and only provides a few formulas. The hint provided in the original question emphasizes that the vertical velocity component is zero at the maximum height.
Dru2k
I'm having major problems figuring this one out.
The question is from the book, yet their are no sample problems and a handful of given formulas. I've played around with the formulas with substitution, etc and I've end up with the wrong answer.
Given: Angle of projectile fired and final displacement along X axis.
angle = 25 degrees
final displacement of x = 301.5 m
acceleration = -9.81m/s^2
Find: Maximum height of Y.
any ideas how I can manipulate the standard formulas of projectile motion to solve for this problem?
horizontal displacement = v(cos theta) t
vertical displacement = 0 = v(sin theta)t + 1/2 (-9.8) t^2
re-arrange each formula, solving for t, and set them equal to each other.
THen solve for v
then solve for max height.
You could also use the range equation to solve for initial velocity. Then use that to find max height.
can you help me find my mistake. i worked it out to the best of my ability.
rearranging displacement of x
t = 301.5m / v cos 25
rearranging displacement of y
t = -2 ( v sin25) / -9.81
than using t = t
-2 ( v sin 25) ( v cos 25) = 301.5 (-9.81) -->
V^2 = sqroot [ (301.5(-9.81)) / -2 sin25 cos 25
V = 62.1 m/s
T = 301.5m / 62.1m/s cos 25 = 5.36s
maximum height with no air resistance would be at half of time
displacement of y = v sin 25 ( t ) + (1/2) (-9.81) (t^2)
y = 62.1 sin 25 (2.68) + 1/2 (-9.81) (2.68^2)
maximum y = 70.3 - 35.2 = 35.1
answer in book says it is 70.3m
what did i do wrong?
maybe this will help
Exact question from book: A golfer can hit a golf ball a horizontal distance of over 300 m on a good drive. What maximum height will a 301.5m drive reach if it is launched at an angle of 25.0 degrees to the ground? (Hint: At the top of its flight, the ball's vertical velocity component will be zero)
Your calculations are correct!
-- AI
I found this video helpful! check it out
  • · Replies 53 ·
