New Reply
the mass flow rate in a heat exchnager
Share Thread Thread Tools
Dec28-10, 12:59 PM   #1
Refrigerant-134a is to be cooled by water in a condenser. The refrigerant enters the condenser with a mass flow rate of 6 kg/min at 1 MPa and 70oC and leaves at 35oC. The cooling water enters at 300 kPa and 15oC and leaves at 25oC. Neglecting any pressure drop, determine
(a) the mass flow rate of the cooling water required.
(b) the heat transfer rate from the refrigerant to water.
a)I worked it out and my answer is .35kg/s by using the formula Q=mC(T1-T2)
but the answer is given as 0.486 kg/s
b) still didn't work with it
but the answer is given as 20.35 kJ/s
any help will be appreciated
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Dec28-10, 02:02 PM   #2
Recognitions:
Homework Helper Homework Help
What are the thermal properties of the refrigerant? It looks like you'll need the heat of vaporization and specific heats for liquid and vapor states.
Dec28-10, 02:17 PM   #3
Quote by gneill View Post
thnx for the reply
But i dont think that we should find the heat vaporization for liquid and vapor state, because we didn't deal with such thing in class , but we do need to find the specific heat of the refrigerant-134a to be able to use the formula which i post above .
Dec28-10, 02:20 PM   #4
Recognitions:
Then you should supply the value if it is required.
Dec28-10, 04:12 PM   #5
Recognitions:
If you have the refrigerant tables for R-134a, you can alternatively use:
(mΔh)R134a = (mΔh)water
Dec28-10, 04:37 PM   #6
Quote by rock.freak667 View Post
Thats exactly what i did , i found a table at the end of my book and finally i got the right answer
Thanks for both of you
New Reply
Thread Tools
Similar Threads for: the mass flow rate in a heat exchnager
Thread Forum Replies
Rate of heat flow problem Introductory Physics Homework 23
flow rate and heat analysis Materials & Chemical Engineering 18
Effect of specific heat of a substance on the rate of heat flow Chemistry 4
rate of heat flow Advanced Physics Homework 1
Question About Mass and Mass Flow Rate Relations General Physics 4
