Curved or non-curved space, what is more fundamental?
  • Context: Graduate
  • Thread starter Thread starter exponent137
    Fundamental Space
The discussion revolves around the concept of whether curved or non-curved space is more fundamental within the context of general relativity and geometry. Participants explore the implications of each perspective, questioning the definitions and relationships between these two types of space.
  • Some participants suggest that non-curved space may be more fundamental based on intuition.
  • Others argue that general relativity implies no inherent priority between curved and non-curved space.
  • A participant questions the meaning of "more fundamental," proposing that it could relate to the nature of geometry as a consequence of physics.
  • One participant points out that the area of a rectangle in non-curved space is defined differently in curved space, suggesting implications for the Pythagorean theorem.
  • Another participant references Kip Thorne's work, indicating that general relativity can be formulated in both flat and curved spacetime, but expresses uncertainty about this without qualifications.
  • Concerns are raised about the use of the term "fundamental" in relation to spaces, with suggestions that it may apply more appropriately to theories rather than geometrical spaces.
  • A later reply challenges the assertion that there is no difference between accelerated frames and gravitational fields, stating that gravitational fields exhibit tidal effects.
Participants do not reach a consensus on whether curved or non-curved space is more fundamental. Multiple competing views and interpretations remain, particularly regarding the definitions and implications of "fundamental" in this context.
There are unresolved questions about the definitions of fundamental and general in relation to space and theories, as well as the implications of geometry being a consequence of physics versus the other way around. Additionally, the discussion touches on the limitations of certain formulations of general relativity.
curved or non-curved space, what is more fundamental?
  • non-curved space is more fundamental
    Votes: 0 0.0%
  • it is no difference between curved and non-curved space
    Votes: 0 0.0%
  • I do not know
    Votes: 1 100.0%
  • other
    Votes: 0 0.0%
  • Total voters
exponent137
By intuition it seems that non-curved space is more fundamental.
By general relativity and difeomorphism it seems that no one is more fundamental.
But how it is with this?
What do you mean by "more fundamental"?
1. According to general relativity there is no difference in priority between curved and uncurved space? Is this true?
2. Area of rectangle in non-curved space is S=a x b. In curved space this is not true.
3. According to 2., Pythagoras theorem is fundamental property of geometry, if noncurved space is more fundamental. If this is not true, Pythagoras theorem is consequence of physics.
"Difference in priority"? You mean that when curved and uncurved space arrive at a formal ball which one is announced first? You keep using very strange words here. Perhaps you are a non-native english speaker?
If so, let me suggest the word "general". Curved spaces are more general than flat spaces because a flat space is a special case of a curved space where the curvature goes to 0.
Yes, I am not native speaker, but it is not easy find words here in any language.
1. We know, that there is no difference between accelerated frame and gravity field. Is similarly a difference between curved and non-curved space.
2. Or maybe differently: I suppose that geometry is a consequence of physics. So I suppose that Pythagorean theorem is a consequence of physics.
If it is a consequence of geometry, not physics, then non-curved space is more fundamental?
Kinetic energy as sum of two orthogonal directions is:
mv_x^2+mv_y^2=mv^2
and it gives pythagoras theorem without geometry.
There is an explicit statement in Kip Thorne's popular book that GR can be formulated equivalently as a flat spacetime or a curved spacetime theory. I am not sure this is true without qualification. The closest I have been able to find is Eq 62 of http://www.emis.de/journals/LRG/Articles/lrr-2006-3/ which comes with the proviso that the spacetime can be covered by harmonic coordinates. (MTW also says the same thing as Thorne's popular book and gives a reference to ... )
Work like http://arxiv.org/abs/1008.3177 seems to indicate the the restriction to harmonic coordinates does not give the full solution space of GR, and that generalized harmonic coordinates are needed for that.
The word "fundamental" simply doesn't apply to spaces. AFAIK, you can use the word "fundamental" to distinguish between two theories or two particles. In the case of theories, if theory A reduces to theory B in some specific limit then theory A could be called more "fundamental" than theory B. It could also be called more "general" than B, so in this context "fundamental" and "general" are synonymous which is why I suggested the word "general" instead of "fundamental". Clearly theories which permit curved spacetimes are more general than theories which permit only flat spacetimes since they will reduce to the flat-spacetime theories in the appropriate limits.
If this concept is not what you are getting at then you will need to carefully explain what you mean by the word "fundamental".
We certainly don't know that, because it is not true. There is a difference. Gravitational fields have tides.
  • · Replies 37 ·
  • · Replies 30 ·
  • · Replies 62 ·
