Cation Exchange Capacity (CEC) of montmorillonite (the calculation)
The discussion centers around the calculation of the required amount of cationic surfactant for modifying montmorillonite (MMT) based on its cation exchange capacity (CEC). Participants explore the methodology for determining the surfactant quantity needed for effective intercalation into the clay structure, with a focus on the implications of CEC values and the efficiency of different surfactants.
  • One participant expresses confusion about how to calculate the weight of the cationic surfactant needed based on the CEC of montmorillonite, specifically referencing a lack of information in the literature.
  • Another participant suggests that the CEC can be used as an upper bound for the surfactant's exchange capacity, noting that the efficiency of the surfactant may differ from that of the ammonium ion.
  • A different participant reiterates their struggle with the calculation and requests assistance, indicating frustration with the lack of clarity in the literature.
  • One participant attempts to guide the discussion by suggesting a hypothetical scenario using a larger sample size to illustrate how to approach the calculation, but does not provide a definitive answer.
Participants generally agree on the importance of CEC in determining the amount of surfactant needed, but there is no consensus on the specific calculation method or the efficiency of different surfactants in this context. The discussion remains unresolved regarding the exact calculation process.
Participants mention the need to consider factors such as the efficiency of the surfactant compared to ammonium ions and the time required for larger surfactant molecules to intercalate into the clay, which may affect the calculation.
yijing84
I am going to modified the pristine montmorillonite (MMT) by using cationic surfactant.
However I am confusing on the way to calculate the weight of the surfactant.
I have been searching hundred of journals but couldn't get any information on how to calculate it.
For example:
MaterialsThe commercial sodium montmorillonite (Cloisite®Na) used in the present study was supplied by Southern Clay Products, Gonzales, Texas (USA). The cation exchange capacity (CEC) of montmorillonite (MMT) is 92.6 mequiv/100 g as reported by suppliers. The basal spacing of MMT is 12.1 Å. This MMT was used as such without any further purification. Various amines used as cationic surfactant.
Organoclay preparation and characterizationThe required amount of amine (taken as twice the amount required based on CEC of MMT) based on 2.5 g of Cloisite®Na was protonated in 100 ml of 1 N HCl for 1 h at room temperature with vigorous stirring to obtain the ammonium chloride salt.
However, they do not state that how to calculate the required amount of amine based on CEC??
Anyone can help me out in this?
Thank you so much in advance.
Chemistry news on Phys.org
Cation exchange capacity is calculated using an ammonium salt. If your surfactant can occupy the anionic sites as easily as ammonium ion, then calculate the amount of surfactant using its formula wt. This example of montmorillonite's CEC is 92.6 milliequivalents per 100g of dry clay. Your amine surfactant is very likely to be less efficient at exchange than the much smaller, more mobile ammonium ion. It is left to you to determine your clay's "surfactant" exchange capacity. The CEC will be the upper bound to what is possible. Also, it takes time for larger species to intercalate into the clay so that factor is also left for you to consider. Google "surfactant pillared clays" to see what others have reported.
I had gone through many literature but I still can't figure out how to calculate the amount of surfactant needed.Can anyone show me the calculation please?
My head is going to blow-up because of this...
Thank you so much.
yijing84 said:
... based on 2.5 g of Cloisite®Na was protonated in 100 ml of 1 N HCl for 1 h at room temperature...
See here? Your sample size is 2.5 grams. How much amine for such a small sample?
Well, if you chose to use a 100 gram sample, and the CEC of the MMC is 92.6 meq/100 grams, and the instructions tell you to use twice that amount of amine...
Can you take it from here?
  • · Replies 37 ·
9K
