| Thread Closed |
Basic Newtonian Questions #2 |
Share Thread | Thread Tools |
| Oct4-04, 08:12 AM | #1 |
Hello Everyone. This is my second posting regarding some introductory physics questions. I am studying physics and taking an on-line course. The last time that I posted I did so under classic physics. I thought that I would also try general physics. I hope this is not too fundamental for the viewers but I would appreciate your review and comments. I have marked the answers that I thought were correct based upon my readings and review of my notes. Physics is tough stuff to comprehend. Thanks.
1. An object moves with a constant speed of 20 meters per second on a circular track of radius 100 m. What is the acceleration of the object? a. zero b. 0.4 m/s/s c. 2 m/s/s d. 4 m/s/s* 2. What force is needed to make an object move in a circle? a. kinetic friction b. static friction c. centripetal force* d. weight 3. A car goes around a curve of radius r at a constant speed. What is the direction of the net force on the car? a. toward the curve's center* b. away the curve's center c. toward the front of the car d. toward the back of the car 4. If a car goes around a curve at half the speed, the centripetal force on the car is: a. four times as big b. half as big c. one-fourth as big* 5. According to Newton, the greater the distance between masses of interacting objects, the: a. less the gravitational force between them b. more the gravitational force between them c. less the force by the square of the separation distance* d. none of these 6. If the radius of earth somehow decreased with no change in mass, your weight would: a. increase b. not change* c. decrease 7. The force of gravity acting on you will increase if you: a. burrow deep inside the planet b. stand on a planet with a radius that is shrinking c. both of these* d. none of these 8. A hollow spherical planet is inhabited by people who live inside it, where the gravitational field is zero. When a very massive ship lands on the planet’s surface, inhabitants find that the gravitational field inside the planet is: a. still zero b. non-zero, directed toward the spaceship c. non-zero, directed away from the spaceship* 9. A very massive object A and a less massive object B move toward each other under the influence of mutual gravitation. Which force, if either, is greater? a. The force on A* b. The force on B c. Both forces are the same 10. A woman who normally weights 400 N stands on top of a very tall ladder so she is one earth radius above the Earth’s surface. How much does she weigh there? a. zero b. 100 N c. 200 N d. 400 N* e. none of these |
| Oct4-04, 09:23 AM | #2 |
6a 7b 8b 9c 10b
I think you are not familiar with the g-r graph. Try studying it and you'll find it helpful in solving a lot of problems. |
| Oct4-04, 09:29 AM | #3 |
But [tex]F=\frac{GM}{R^2}[/tex] where M is the mass of the Earth and R the radius of the Earth. Combining the two equations, we see that m is inversely proportional to [tex]R^2[/tex]. I will put up the rest of the answers next time 'coz I really have to run now. Bye!!! |
| Oct4-04, 01:13 PM | #4 |
Thanks for the quick response John54. My on-line course is pretty basic. It contains short tutorials and numerous self-assessment questions. There is also a workbook but neither the learning system or workbook goes into great depths. What is the g-r graph? I appreciate the answers that you gave me but I want to know, in common terms, why those answers are correct. You gave me a good starting point. I will start with #6. If the radius of earth somehow decreased with no change in mass, your weight would: (a.) increase, (b.) not change, (c.) decrease. I am changing my answer to (a) increase. My reason is as follows (my words trying to explain the equation F=GM divided by R squared): The gravitational force responsible my weight is equal to some constant G x the Earths mass divided by the Earth's radius squared. So if we keep the mass of the Earth constant and shrink the Earth's radius then the resulting gravitational force would be greater because the radius squared is much smaller. This number is then divided into the GM (with mass staying the same) results in a greater value for the gravitational force. Weight would increase. I remember a cartoon illustration that showed how being closer to the center of the planet increases the gravitational pull and the value for your weight. Please say this is right. My head is spinning.
| Oct4-04, 01:21 PM | #5 |
Thanks Deydas. It is these equations that make my head spin. But I think I get the logic. I responded to John54 expaning problem 6. Am I correct that the answer should be (a) increase for the reasons that I stated. Your weight is dependant on the mass of the planet you are on and the distance you are from the center of the planet? If the planet's mass stays constant but the radius gets smaller your weight has to increase. I hope this is the correct explanation. Also, in your equation is the F = gravitational force and G some constant? Also, how did you merge the two equations to show that your weight is inversely proportional to the radius squared? Thanks for assisting a true beginning physicist (I say this with tongue in cheek).
| Oct4-04, 01:48 PM | #6 |
Mentor
To be clearer: Your weight equals the gravitational attraction between you and the earth. That force equals: [tex]F = G M m / R^2[/tex], where M is the mass of the earth and m is your mass. In problem #6 the only thing that changes is that R gets smaller--thus your weight increases. |
| Oct4-04, 02:02 PM | #7 |
Mentor
| Oct4-04, 02:22 PM | #8 |
Hello Doc Al. I knew it would not be long to hear from you when you saw me struggling. Will I ever have a "physicists" way of thinking? I hope at least to be able to capture the basics. Thanks for you assistance again. I know that I am too logical, sequential, anal-retentive but these formulas just mess up my thinking when I can not see the connections. I get the concepts but sometimes the formulas make me re-think or change my mind in processing the information. Even in your explanation I am wondering if the g is equal to the F and in your statement "Combining the two equations, we see that m is inversely proportional to R squared. I assume you mean that a body's weight is inversely proportional to R squared." The m is not even in the equation unless you mean it is included in the F because it is equal to GMm/R squared. Again, please say that I am correct. Thanks for your patience.
| Oct4-04, 02:30 PM | #9 |
John54. Hello again. I research #7 The force of gravity acting on you will increase if you (a.) burrow deep inside the planet, (b.) stand on a planet with a radius that is shrinking, (c.) both of these, or (d.) none of these. I am not sure why the answer is not what I originally posted (c.) both of these. I thought that the weight of an object equals the gravitational attaction between the two objects (person and planet) and that the body weight is inversely proportional to the planet's radius squared. Or if mass of the planet increses or it diameter (radius) gets smaller the resulting force (weight) would increase. If you dig a hole in the planet and get closer to the planets center (same as decreasing the radius) this would result in an increased weight. Where did I go wrong?
| Oct4-04, 02:36 PM | #10 |
Mentor
I think deydas was trying to say this: (1) W = mg (2) g = GM/R^2 Thus W = GMm/R^2. The weight is inversely proportional to the square of the Earth's radius. That's fine, but you could have started with that answer based on Newton's law of gravity. |
| Oct4-04, 02:46 PM | #11 |
Mentor
As you tunnel into the planet, only the mass underneath you affects your weight (assuming a symmetrical distribution of mass). Assuming a uniform density, the mass underneath you is proportional to the radius cubed. That ends up making the net gravitational force on you--your weight--directly proportional to the radius. So your theoretical weight decreases from a maximum at the surface to zero at the center. |
| Oct4-04, 03:11 PM | #12 |
Doc Al. Sorry about posting in two forums. I did not know that was a rule. Also, was not sure if General or Classical was the way to go. I know my questions are very basic but I enjoy the site. I think that I am learning as much here as I am with my on-line learning system and readings. Thanks for your patience.
| Oct4-04, 03:39 PM | #13 |
physicsnovice, you may try out Fundamentals of Physics by Resnick, Halliday and Walker. The text is wonderful and the concepts (along with the formulae) is very clearly explained. And I am sorry for not being able to explain the problems properly. I will try my best next time.
Thank you. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Basic Newtonian Questions #2
| Newtonian Gravity questions | Introductory Physics Homework | 1 | ||
| the basic questions | Special & General Relativity | 9 | ||
| Basic Newtonian Problems #2 | Classical Physics | 1 | ||
| Basic Newtonian Physics Questions | Classical Physics | 9 | ||
