New Reply
Star-delta Starter
Share Thread
Jan2-11, 07:59 AM   #1
Star-delta Starter
Hi, I got a small problem which I'm not sure I'm solving correctly. A small induction motor has a short circuit current equal to 5 times the full-load current. I need to find the starting torque as a percentage of full load torque if the motor is started by a star-delta starter. It is also known that the motor has a full load slip of 4%.
[tex] Torque = \frac{3I_{R}^2R_r}{(s*\omega_s)} [/tex]
[tex] T_{start}= \frac{3(\frac{5}{3} I_{FL})^2R_r}{\omega_s} [/tex]
Note that in the above equation i divided the current by three because in a star-delta starter the current is supposed to be 1/3 the direct online current.
and [tex] T_{FL} = \frac{3I_{FL}^2R_r}{0.04\omega_s} [/tex]
Then dividing (1) by (2) i should get [tex] \frac{T_{start}}{T_{FL}}=(25/9)*0.04=0.11 [/tex].
That is equivalent to 11.1% of the Full load torque. However my lecturer got the answer as 33.33%, which is probably because he did [tex] \frac{i^2}{3} [/tex] instead of [tex] (\frac{i}{3})^2 [/tex]. Is my answer incorrect?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jan3-11, 12:07 PM   #2
Anyone please? I have done some additional reading about the problem but I still can't see where I could have made a mistake. The problem is that in another very similar question I also got the answer wrong by using this "method", if you can call it that.
New Reply
Similar discussions for: Star-delta Starter
Thread Forum Replies
Monty hall problem in the movie 21 Academic Guidance 2
Star-Delta Resistance Conversion Advanced Physics Homework 2
Star Delta Transformation Proof Engineering, Comp Sci, & Technology Homework 6
Astrophysics Starter Astrophysics 8
uP starter kit Electrical Engineering 4
