WIKI and Time Dilation: The Possible Error in Relative Velocity
The discussion revolves around the interpretation of time dilation as presented in a Wikipedia article, specifically questioning the accuracy of the claims regarding the relationship between moving and stationary clocks. Participants explore the implications of the Lorentz-Fitzgerald formula and the definitions of rest and moving frames in the context of special relativity.
  • Some participants suggest that the Wikipedia article contains errors regarding time dilation, particularly in how it describes the relationship between the moving and stationary clocks.
  • Others argue that the standard explanation of time dilation is correct and aligns with the Lorentz-Fitzgerald formula, emphasizing that in the moving frame, the clock runs slow.
  • A participant points out the importance of distinguishing between delta t and t in the context of time dilation, suggesting that confusion arises from this terminology.
  • Some participants emphasize that motion is relative and that no frame can be definitively labeled as "moving" or "stationary," which complicates the interpretation of the time dilation formula.
  • One participant recommends using the complete Lorentz transform instead of simplified formulas to avoid misapplication and confusion.
  • There is a discussion about the conventions used in different sources regarding which frame is considered the rest frame, with some participants asserting that the unprimed frame is the rest frame while others contest this interpretation.
Participants do not reach a consensus on the accuracy of the Wikipedia article or the interpretation of time dilation. Multiple competing views remain regarding the definitions of rest and moving frames, as well as the implications of the time dilation formula.
Participants express uncertainty about the definitions of rest and moving frames, and there are unresolved questions about the application of the time dilation formula in different contexts. The discussion reflects a variety of interpretations and conventions in the literature.
Seems like the standard explanation and the simplest way of deriving the lorentz-fitzgerald formula, what's the problem ?
It states t' = t γ and t is from the rest frame. That means if t is 1s and since γ > 1, then t' > t which means more time on primed clock which is moving.
chinglu1998 said:
...t' > t which means more time on primed clock which is moving.
Why do you write t? It's delta t. You're looking for trouble.
What?
Delta t then.
Do you have a comment on the OP? Is WIKI correct?
chinglu1998 said:
What?
Delta t then.
Yes, it's correct. In the primed frame where the clock is moving, the clock is running slow so it takes more time to tick forward by a given amount. For example, if a clock is moving at 0.6c in my (primed) frame, it takes 25 seconds in my frame for the clock to tick forward by 20 seconds of its own time.
Also, I don't understand your use of the phrase "more time on primed clock which is moving". Motion is relative, there is no objective truth about which is "moving". The time dilation formula assumes you have a clock at rest relative to the unprimed frame, and which is moving relative to the primed frame, and you want to know how much time goes by in the unprimed frame when the clock ticks forward by a given amount.
I strongly and consistently recommend against ever using either the time dilation or length contraction formulas. It is too easy to use it incorrectly, and it doesn't save a significant amount of effort.
I recommend always using the complete Lorentz transform. This avoids any risk of using the simplified formulas when they do not apply, and it automatically simplifies when appropriate.
Well Einstein wrote the following
τ = t √( 1 - v²/c² )
http://www.fourmilab.ch/etexts/einstein/specrel/www/
Section 4 halfway down.
t is in the rest frame time and this is the same as WIKI, the unprimed frame is the rest frame.
Both WIKI and Einstein used the unprimed frame as the rest frame.
So, let say the rest frame (unprimed frame) ticked 20 seconds.
Einstein said τ = 20 √( 1 - (.6c)²/c² ) = 20 √( 1 - (.6c)²/c² ) = 20 √( .64) = 20 (.8) = 16.
Thus, the moving frame ticked 16 seconds or slower than the rest unprimed frame.
This is not what WIKI says.
WIKI claims the moving frame ticks off more time.
I agree, but, if you look at WIKI, it has the rest frame beating slower or the moving frame clock beating faster. The unprimed frame is the rest frame.
The example said the primed frame was the moving frame. And the unprimed frame is taken at the stationary system of coordinates. So, that means the clocks in the primed frame are moving relative to the unprimed frame.
I think you're confused about how relativity works, no frame is declared "moving" or "stationary" in any absolute sense, you can only talk about relative motion. The primed frame is moving relative to the unprimed frame, and the unprimed frame is moving relative to the primed frame. Clocks at rest in the unprimed frame are running slow in the primed frame (and the wiki article is specifically considering a clock at rest in the unprimed frame), just as clocks at rest in the primed frame would be running slow in the unprimed frame (though the time dilation equation in the wiki article doesn't deal with this case).
chinglu1998 said:
The following have the unprimed frame as rest frame.
What do you mean by "rest frame"? Do you understand my point that no frame is declared to be "at rest" in any absolute sense, you can only talk about a frame as the "rest frame" of some particular object? In the wiki, the unprimed frame is the rest frame of the clock, and the primed frame is the rest frame of the observer.
chinglu1998 said:
Yet, WIKI claims the opposite.
No, it says the unprimed frame is the rest frame of the clock being considered in the time dilation equation. Some of the links you gave do use a different convention, but in any case it's purely a matter of convention which coordinates we use to label time in the clock's own rest frame, it's usually the primed frame but it could be the unprimed frame.
I can't see how you conclude I said any frame is at absolute rest.
I said when the frame is taken as stationary.
So, I think you are claiming, if the unprimed frame is taken as stationary, the moving clocks in the primed frame are beating slower.
You can tell the unprimed frame is at rest with the light source because there is no light abberation (angle to the light beam).
So, the unprimed frame is considered stationary and the primd frame is considered the moving frame. Clocks therefore, when viewed from the stationary frame are time dilated.
For example, when do you say you are in the moving frame and the clocks in the other frame are at rest?
Do you see this makes no sense what you say?
No, it also says the unprimed frame is the rest frame of the clock being considered in the time dilation equation, just like the other links you gave.
Then is it possible you compare the equations?
WIKI says t' = t γ
The others say t' = t / γ.
Can you see the difference?
WIKI says t' = t γ
While you were posting this I was editing my post to read:
I agree with you the convention is important.
But, the fact that the unprimed frame has no light abberation clearly indicates that frame is at rest with the light source which is being used to determine time dilation and that plus the fact WIKI said the unprimed frame is at rest, I am not sure what other evidence I could produce that the unprimed frame is not moving and any clock in the primed frame is.
Moving clocks beat time dilated and that is not what the equation on WIKI shows.
"Taken as stationary" relative to what? Better to say it's the rest frame of the observer, I think.
The phrase "taken as stationary" doesn't seem to add any meaning here. I would just say that from the perspective of the unprimed frame, the clocks in the primed frame are moving and beating slower.
Or you could just note that the position of the source in the unprimed frame doesn't change with time.
Again the words "stationary" and "moving" are completely unnecessary and confusing. I would just say "clocks at rest in the unprimed frame, when viewed from the primed frame are time dilated"
"At rest" is meaningless unless you specify what frame something is at rest relative to. If I am at rest relative to the primed frame, then clocks at rest relative to the unprimed frame are moving relative to me.
Here count the number of times Einstein uses "stationary". 62 times.
I think it has a clear meaning.
It is the rest frame of the light clock whose time dilation we want to determine, as seen in the frame of an observer (the primed frame). Regardless of what symbol convention is used, the time dilation equation always has the following form:
(time interval in frame of observer who sees clock in motion) = (time elapsed on clock)*gamma
No it didn't, it only said the unprimed frame is the one where the clock is at rest. Likewise, the primed frame is the frame of the observer, so it is obviously the frame where the observer is at rest. When the article refers to the "moving observer", they only mean the observer is moving relative to the clock.
As usual, it is physically meaningless to say a given object is "moving" or "at rest" unless you are really saying it is moving or at rest relative to something. It's true that some authors just talk about a "stationary frame" and a "moving frame" but it is always clear from the context that they are implicitly defining motion relative to a particular object or observer. Obviously this convention is getting you all confused because you fail to understand the unspoken "relative to", so I'd suggest that from now on you never use phrases like "stationary" or "moving" unless they are followed by "relative to X", where X is some object or observer.
But he makes clear at the start that he is defining "stationary" and "moving" relative to a particular arbitrarily-chosen coordinate system:
Let us take a system of co-ordinates in which the equations of Newtonian mechanics hold good. In order to render our presentation more precise and to distinguish this system of co-ordinates verbally from others which will be introduced hereafter, we call it the "stationary system.''
If a material point is at rest relatively to this system of co-ordinates, its position can be defined relatively thereto by the employment of rigid standards of measurement and the methods of Euclidean geometry, and can be expressed in Cartesian co-ordinates.
It's just a verbal convention Einstein uses to shorten the presentation, but it's not like it's a basic part of relativity terminology that you must use such a convention, in fact most authors don't pick one frame to label "stationary" and another to label "moving", they just say "stationary relative to X" and "moving relative to X" etc.
You forgot the light abberation. The unprimed frame does not see it but the primed frame does.
So, the unprimed frame is at rest with the light source and the WIKI said the unprimed frame is at rest. They made an error, why is that a problem?
I am not confused, you are. There is nothing in the WIKI article to claim the primed frame is at rest relative to anything. If you can find it, prove it.
And Einstein used the term stationary 62 times in his 1905 article. So, I will continue to use it. I suggest you read the paper before you condemn the usage and indicate why Einstein was in error.
When you take a frame as stationary, you assume the Euclidian Geometry.
When you assume another frame is the moving frame, you apply the Minkowsky Geometry.
This is a vital distinction such that if the distinction is not clear, complete and total breakdown of SR occurs.
So I am not able to make small of it like you are.
Anyway, from any point of view the WIKI article is taking the unprimed frame as stationary. If you see evidence to the contrary, please post it.
Uh how did I forget it? I just said "the unprimed frame is the one where the clock is at rest", and the clock is a light clock, so this is exactly the same as saying the unprimed frame is the one where the light source is at rest.
They said the unprimed frame was at rest relative to the clock/light source ('In the frame where the clock is at rest'), which it is. Why do you have a problem with this?
They used the primed frame to denote "the frame of reference of a moving observer traveling at the speed v" (relative to the clock). Do you deny that this "moving observer" is at rest relative to the primed frame?
He's not in error, because he said at the outside he was defining "stationary" relative to a particular (arbitrary) choice of frame. That's my whole point, that terms like "at rest" and "moving" are only meaningful when they are (explicitly or implicitly) defined relative to some particular frame or object, and there is no requirement that you always define them relative to the same object throughout the problem, you are free to switch between saying an object is "moving relative to frame X" and "at rest relative to frame Y" if you so choose. Do you think there is some rule that says this is forbidden?
What do you mean "assume Euclidean geometry"? Can you give a numerical example?
And can you give a numerical example of "apply the Minkowski geometry"? Normally I would say that Minkowski geometry is defined in terms of the metric, which says that the proper time between two events with coordinate separations [tex]\Delta t, \Delta x, \Delta y, \Delta z[/tex] is given by the formula [tex]\sqrt{\Delta t^2 - (1/c^2)*(\Delta x^2) - (1/c^2)*(\Delta y^2) - (1/c^2)*(\Delta z^2)}[/tex]. But this is true in all frames, even if we choose to label one of the frames as "stationary" like Einstein does. So I have no idea why you think Minkowski geometry doesn't apply in what you call the "stationary frame".
Again, a numerical example of what you mean by "breakdown of SR" would be helpful.
The article defines "stationary" and "moving" relative to the clock. But as I said, the time dilation equation always has the following form:
This is true regardless of whether you label the clock's frame as "stationary" or label the observer's frame as "stationary" or don't label either frame as "stationary". All that's required to have a correct expression of the time dilation equation is that it match the form above. Do you disagree? Can you think of a scenario where the time in the observer's frame and the time in the clock frame would not be related by the equation above, perhaps because we switch which is considered "stationary" and which is considered "moving"?
So, how are you supporting the notion that t' = t γ as posted on WIKI? Everthing says there the unprimed frame is at rest. This equations implies the moving frame (primed frame) beats faster and that is an error.
They said it was at rest relative to the clock/light source ('In the frame where the clock is at rest'), which it is. Why do you have a problem with this?
I do not. I just understand everything points to the unprimed frame as at rest. Check all my links. It is standard convention that the unprimed frame is at rest. And, WIKI confirms this.
In the frame where the clock is at rest Refers to unprimed frame.
From the frame of reference of a moving observer traveling at the speed v
http://en.wikipedia.org/wiki/Time_dilation
It is clear the unprimed frame is at rest. I think you have a problem admitting you are wrong.
No, so what. Did you say "moving"?
Yes, and the WIKI article is clear the stationary frame is the unprimed frame. Its conclusions are in error. Do you agree with them?
The way a clock ticks in different frames has nothing to do with the totally arbitrary labels "moving" and "at rest" which we may apply to different frames. As I keep telling you, the basic idea of the time dilation equation is this:
If you make the arbitrary choice to label the clock's frame as "moving" and the observer's frame as "stationary", then it can be interpreted in this way:
(time between two readings on the clock as measured in stationary frame) = (time between two readings on the clock as measured in moving frame)*gamma
On the other hand, if you make the equally arbitrary choice to label the clock's frame as "stationary" and the observer's frame as "moving", then it can be interpreted in this way:
(time between two readings on the clock as measured in moving frame) = (time between two readings on the clock as measured in stationary frame)*gamma
Both are valid, given the aforementioned arbitrary choices about which frame to label as "stationary" and which to label as "moving". Do you disagree? If you do, then it seems you believe that stationary vs. moving does have some absolute significance, since you think we are not equally free to label the clock's frame as "moving" or "stationary" (in which case you are very confused about how relativity works, since in relativity there is no way to detect any absolute motion). On the other hand, if you agree both are valid given the right arbitrary choice of labels, then you should be able to see that the wiki article was simply adopting the second convention.
You are not going to win in this direction just because you made an error about WIKI.
Let us take a system of co-ordinates in which the equations of Newtonian mechanics hold good.2 In order to render our presentation more precise and to distinguish this system of co-ordinates verbally from others which will be introduced hereafter, we call it the ``stationary system.''
The "Newtonian mechanics hold good" in the Euclidean geometry.
Uh, try selecting points from the light sphere in the stationary frame and mapping them with LT.
You will note the points on the light sphere satisfy x² + y² + z² = c² t².
Uh, this is a Euclidean object. Do you now understand the Euclidean nature of the stationary system of coordinates?
Now, let's look at the Minkowsky interpretation.
ξ² + η² + ς² = c² τ²
τ = ( t - vx/c² )γ
ξ = ( x - vt )γ
η = y
ς = z.
This is not Euclidean because the radius of this light sphere is not the same in all directions.
Fine show where the WIKI article shows the primed frame is stationary as you claimed.
Oh, no I do not agree with absolute positions. I know the conventions. I just know every scrap of evidence on the WIKI problem proves the unprimed is the stationary frame.
I also know you will type thousands of pages rather than simply admitting you are wrong.
There is no coordinate system where all the dynamical predictions of Newtonian mechanics hold good (for example, Newtonian dynamics would predict that a clock ticks at the same rate regardless of its velocity). But if you pick some specific features of Newtonian mechanics which still hold in relativity, like the fact that an object moving at constant velocity remains at that velocity unless acted on by a force, then these features hold in all inertial frames in relativity, not just one. If you disagree, please name a specific Newtonian law which you think holds in one inertial frame (the 'stationary' one) but not others.
τ = ( t - vx/c² )γ
ξ = ( x - vt )γ
η = y
ς = z.
Uh, I think you are forgetting about the relativity of simultaneity. A "light sphere" is just the set of points in spacetime that light from a flash has reached at a single moment in time in one frame, but if you map this set of points to a different frame, then in that frame they will consist of events at different times. If instead you consider the light cone as is normally done in relativity, then if you look at the subset of events on that cone which all occur at some time T in the unprimed frame, their positions in the unprimed frame will form a sphere satisfying x2 + y2 + z2 = c2 T2, and likewise if you look at a different subset of events on that cone which all occur at some time T' in the primed frame, their positions in the primed frame will form a sphere satisfying x'2 + y'2 + z'2 = c2 T'2. You really are very confused if you think that light expands spherically in one inertial frame but elliptically in a different inertial frame--that would violate both the first and second postulates of special relativity! This issue of light spheres vs. light cones and why each frame sees the light as a sphere at any single instant was discussed extensively on this thread, if you're interested.
  • · Replies 58 ·
  • · Replies 79 ·
  • · Replies 47 ·
  • · Replies 46 ·
  • · Replies 27 ·
  • · Replies 54 ·
