Does Bohr's Model of Hydrogen Still Hold Up Against Quantum Mechanics?
  • Context: Graduate
  • Thread starter Thread starter PeteGt
    Bohr Hydrogen
The discussion centers on the validity of Bohr's model of the hydrogen atom in light of quantum mechanics. Participants explore whether Bohr's model remains applicable or if it has significant limitations compared to more modern quantum mechanical approaches, particularly in relation to electron behavior and energy levels.
  • Some participants note that while Bohr's model provides correct energy levels for hydrogen, it has key physical flaws, particularly in its classical interpretation of electron orbits.
  • Others argue that Schrödinger's equation presents a more accurate depiction of electrons as probability densities rather than classical orbits.
  • It is mentioned that Bohr's model fails to predict fine spectral structures and the behavior of more complex atoms, with Sommerfeld's model being an attempt to address some of these issues, albeit with its own limitations.
  • Some participants highlight that Bohr's radius retains physical significance, with discussions on the time-averaged displacement from the nucleus and the R.M.S displacement being equal to the Bohr radius.
  • There is a clarification that while the highest probability density for finding an electron is at the nucleus, the actual chance of locating the electron there is extremely low due to the small volume of the nucleus compared to the s orbital.
Participants generally agree that Bohr's model has limitations and that Schrödinger's model provides a more comprehensive understanding of electron behavior. However, there is no consensus on the extent to which Bohr's model can still be considered valid for hydrogen, as some participants suggest it may still hold up in certain contexts.
Discussions include assumptions about the nature of electron localization and the implications of probability densities, which may not be fully resolved. The conversation also touches on the mathematical interpretations of radial and spherical wavefunctions without reaching definitive conclusions.
PeteGt
I searched the forums to find my answer and didn't find anything within the first couple searches.
Here's my question:
Bohr developed his model of the hydrogen atom. Then Quantum mechnics came along.
Does Bohr's model of Hydrogen work for itself? I always thought even though wave mechanics describes everything else appropriately, that hydrogen's model like bohr described was totally okay. I was about to try to work through the calculus and figure it out, but I was wondering if anyone had a quick answer, or maybe even better got a mathcad document I could look at?
Does hydrogen's electron orbit in a discreet and exact orbit at Bohr's radius? Or does it exsist in this s orbital like everything else does?
Thanks in advance.
Peter
The energy levels work out, but there are key physical flaws in the Bohr model.
Schrödinger's equation allows us to look at the electron as probability density, and nothing else. It does not orbit classically as the Bohr model might suggest.
The two major failings of Bohr's model was its failure to predict fine spectral structure and the models inability to predict the behaviour of more complex atoms such as Helium.
Sommerfield proposed an alternative model to Bohr's which could explain fine structure, however it too could not be applied to more complex atoms.
In Schrödinger's model, electrons are not localised and thus thus do not orbit in a classical sense. Bohr's radius still retains physical significance, for while the time averaged displacement from the nucleus is zero, the R.M.S displacement is the Bohr radius.
Claude.
Amazingly, Bohr and Schrödinger agree on the n-dependence of the energy levels of the hydrogen atom. But as has been noted, Bohr doesn't go any further than that. Also, the Bohr model gets the orbital angular momentum totally wrong.
One can expand on this and say that the expectation of the radial displacement from the nucleus is the Bohr radius. As pointed out, the time averaged displacement is nil due to the radial symmetry. But the probability that the electron is inside the actual nucleus is very small.
Gotcha,
So you're saying that <r> is Bohr's Radius, but doing a square of the Radial * Spherical WAvefunctions would lend a possiblity of finding the electron outside of <r> but never at the nucleus. Am I reading this correctly?
Peter
The highest probability density is a the nucleus, however because the volume of the nucleus is small compared to the volume of the s orbital, the chance of finding the electron in the nucleus is vanishingly small (nearly zero, but not quite).
Claude.
  • · Replies 23 ·
  • · Replies 36 ·
10K
