Which Career Path: PhD in Physics or Engineering?
The discussion revolves around the decision-making process regarding pursuing a PhD in either physics or engineering, including considerations of undergraduate degrees and research interests. Participants explore the implications of each path and the potential for interdisciplinary approaches.
  • One participant suggests determining the motivation for pursuing a PhD, emphasizing the importance of aligning the degree with desired research areas.
  • Another participant argues that a PhD in engineering is preferable for engineering research, while a PhD in physics is suited for physics research.
  • A different participant expresses a personal interest in both building and experimental research, indicating a struggle to choose between the two fields.
  • One suggestion is made regarding the possibility of pursuing applied physics as a middle ground.
  • Another participant proposes that obtaining an undergraduate degree in physics followed by a PhD in engineering may be a viable path, noting the likely requirement of a master's degree in engineering beforehand.
  • There is a recommendation to focus on completing an undergraduate degree in the subject that interests the individual the most before making further decisions.
Participants express differing opinions on the best educational path, with no consensus reached on whether a PhD in physics or engineering is preferable. Multiple competing views remain regarding the relationship between undergraduate studies and PhD choices.
Participants mention various assumptions about research interests and educational pathways, but these are not fully explored or resolved within the discussion.
PanderaFlame
Hello, well i am contemplating whether i should get a Phd in physics and a degree in engineering or a PhD in engineering and a degree in physics. Can you help me? Also can i have some reasoning too.
First of all, you should figure out or state, why do you want to get a PhD? To do research? What kind of research? Get the PhD that will lead you to the research you want to do.
Get a PhD in engineering if you want to do engineering research. Get a PhD in physics to do physics research.
:rolleyes:
I can see where both of you are getting at but this is how it goes, i like building things and running experiments research for a thesis sounds good for engineering but i also really like physics I've been going to and fro in my mind for ages so i just need some other opinions.
how about applied physics?
I'd say its probably easier to get an undergrad in physics and then a PhD in engineering (you'd have to do a masters in engineering before hand most likely). However, I recommend just getting through your undergrad in whichever subject you like more, then going from there. And EE is probably the best engineering undergrad if you think you MAY want to go into pure physics later.
  • · Replies 22 ·
  • · Replies 18 ·
