Fluid Mechanics - Turbulent flow velocity profile
The discussion revolves around the velocity flow profile of water in a pipe, specifically under turbulent flow conditions. Participants explore the necessary parameters and equations needed to plot the velocity profile, including the Reynolds number and the seventh power law, while addressing uncertainties regarding dynamic viscosity and temperature assumptions.
  • Homework-related
  • One participant expresses confusion about how to plot the velocity profile without knowing the maximum velocity, which depends on dynamic viscosity or flow rate.
  • Another participant provides the Reynolds number equation and suggests that knowing the Reynolds number allows for the calculation of mean velocity, which could lead to determining flow rate.
  • There is a discussion about the dependency of dynamic viscosity on temperature, with one participant questioning whether to assume ambient temperature.
  • Participants note that the question specifies turbulent flow, indicating an expected pattern for the velocity profile.
  • One participant requests the full question for context, indicating that the temperature assumption is uncertain.
  • The full question is provided, which includes multiple parts related to plotting velocity profiles and calculating mean velocities and friction factors.
Participants generally agree that the turbulent flow condition is established and that the velocity profile can be expected to follow a certain pattern. However, there is no consensus on how to proceed with the calculations due to uncertainties regarding dynamic viscosity and temperature assumptions.
The discussion highlights limitations related to missing assumptions about temperature and the dependence of dynamic viscosity on it. There are unresolved steps regarding how to accurately plot the velocity profile without complete information.
Mechanical engineering students, educators in fluid mechanics, and professionals interested in fluid dynamics may find this discussion relevant.
1trumpet
Hi
I'm a mechanical engineering student who has been set a question by my fluid mechanics lecturer. I need to plot the velocity flow profile of water flowing in a pipe. The information given in the question is
diameter = 0.5m
Re = 10^5
I know that the seventh power law is used to find velocity profile, but I can't see how I can use it without knowing max velocity, and I can't see how I can find max velocity without knowing dynamic viscosity or flow rate.
Am I thinking about this the wrong way? I would appreciate if anyone could point me in the right direction.
Thanks.
Reynolds Number = (pVD) / μ
Where p = density of fluid, V = mean velocity, D = hydraulic diameter, μ = dynamic viscosity.
We know all of those factors aside from V. So you can work out the mean velocity, which should give you the flow rate.
For dynamic/kinematic velocity: http://www.engineeringtoolbox.com/water-dynamic-kinematic-viscosity-d_596.html
I'm not sure if there's anything to work out though. Do you need an accurate plot based on figures or just show the basic flow pattern?
If you know the reynolds number, you know the type of flow within the pipe. From that you should know what type of pattern to expect and you could show the expected profile.
Thanks for your answer.
The dynamic viscosity depends on temperature, which is not given. Or are you suggesting I should assume ambient temperature?
Yes, it is already mentioned in the question that it is turbulent flow, so I know what the pattern should look like. An accurate plot is what I'm after.
I'd appreciate it if you could provide the full question for reference.
So far as temperature goes, I'd prefer to see the question. But I would probably assume ambient.
Here is the question in full:
For turbulent flow, the velocity profile inside a duct and a pipe of diameters Dd and Dp and
both with distance y from the centre line is: vy/vy=0=(1-y/7)1/7, where vy=0=vmean/0.817 and vmean=Q/A. Plot the velocity profiles for:
(a) Air flowing in a duct measuring Dd = 0.6m and with Re = 105.
(b) Water flowing in a pipe measuring Dp = 0.5m and with Re = 105.
(c) Calculate the vmean and vy=0 for both cases (a) and (b)
(d) If the Blasius equation f = 0.079Re-0.25 applies, calculate the values of f and ΔP/L for (a)
was there an answer to this question??
19K
  • · Replies 39 ·
  • · Replies 28 ·
  • · Replies 25 ·
