Find the Average Power of a 560 kg Elevator
The problem involves calculating the average power delivered by an elevator motor as a 560 kg elevator accelerates upward with a constant acceleration for a specified time until it reaches a cruising speed. The context includes considerations of gravitational acceleration and the forces acting on the elevator.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the calculation of acceleration and the formula for power. There are attempts to identify the forces acting on the elevator and how to incorporate them into the power calculation. Questions arise about the steps needed to determine the necessary values for force and distance.
The discussion is ongoing, with some participants providing guidance on drawing free-body diagrams and considering the forces involved. Multiple interpretations of how to approach the problem are being explored, particularly regarding the work done and the forces acting on the elevator.
Participants note the importance of including both the force required to overcome gravity and the work done to increase kinetic energy in their calculations. There is also mention of the need for a clear understanding of the relationships between mass, acceleration, and force.
Unknown_20
Can someone please help with this? Thanks in advance.
A(n) 560 kg elevator starts from rest. It moves
upward for 4.61 s with a constant acceleration
until it reaches its cruising speed of 2.13 m/s.
The acceleration of gravity is 9.8 m/s2.
Find the average power delivered by the
elevator motor during this period. Answer in
units of kW.
What exactly have you tried to do with this problem on your own?
Well, I found that the acceleration is equal to .462039 until the speed is constant. I'm not sure what steps to take from here or if I'm even on the right track.
Correct so far...
Now, how do you calculate power ? What formula is there for that ?
the equation is P=(F*d)/t
That will work. Now what is F = ? and what is d = ? You know what t is.
If I knew that I would not have asked the question.
I'm trying to help you here, so it would be in your interest to simmer down.
Okay, why don't you draw the free-body diagram for the elevator ? What are the different forces acting on it ? What is the net force equal to ? And you know the mass and acceleration. Use Newton's Third Law to find the relation between the net force and the acceleration. From this, you can find the value of F.
You know the final velocity, total time taken calculate the acceleration. Multiply it withh mass it will be the work done by it divide it by total time taken.
knock-knock, who's this, your answer.
Another way,
calculate the height at which it reached multiply it with mass and acc. due to gravity it will be the work done divide it wih time.
No, mass*acceleration is not the work done. And one more thing you're forgetting here is the force needeg to bear the weight of the elevator. You must include that too.
Another way,
What about the work done to increase the kinetic energy ? If you include that, this method will work.
  • · Replies 31 ·
